[OpenLayers-Users] GML Overlay
Dash jimlug at co.clackamas.or.us
Thu Sep 17 14:10:07 EDT 2009
Ok, I'm still stuck on this.  It seems that none of them work.  Could some
review this to make sure that I'm doing it correctly?
var gml = new OpenLayers.Layer.GML("GML", "./jlpts.gml");
var gmlVector = new OpenLayers.Layer.Vector("GML", gml, {
	format: new OpenLayers.Format.GML(gml),
	formatOptions: {
		xy: false
Christopher Schmidt-2 wrote:
> On Wed, Sep 16, 2009 at 02:15:14PM -0700, Dash wrote:
>> Well, I figured out the answer.  The Data Interop. Tool by ESRI outputs
>> the
>> coordinates in a lat / long format.  Well, OpenLayers and the GML file
>> require the coordinates to be in a long / lat format.  What a pain in the
>> butt!  Now, does anyone know how to fix that?
> GML Format option: "xy: false"
> So, in a Vector Layer:
>  Vector("", "file.gml", {format: OpenLayers.Format.GML, formatOptions:
> {xy: false}});
> -- Chris
>> >> On Tue, Sep 15, 2009 at 11:42:47AM -0700, Lugosi, Jim wrote:
>> >>> I am trying to figure out how to use the GML overlay with OpenLayers.
>> I
>> >>> have searched high and low for examples and nothing seems to help.  I
>> am
>> >>> currently trying to convert a shapefile to a GML file using ESRI's
>> Data
>> >>> Interop. Tool.  I've used both the quick export and the Spatial ETL
>> >>> Tool.  Everything seems to work, but when I try to display the
>> >>> information on my map nothing shows up.  There are no JavaScript
>> errors
>> >>> and the layer shows up in my LayerSwitcher control so I really can't
>> >>> tell what the problem is.  Also, I've dumbed down the process by
>> >>> creating a shapefile of a box so that I don't have a large number of
>> >>> coordinates.  Could someone please help with my dilemma?
>> >> http://docs.openlayers.org/help/minimize.html
>> >>> Thanks...
>> >>> James Lugosi
>> >>> Clackamas County - GISP
>> >>> www.clackamas.us/gis
>> >>> 503-723-4829
>> >>> _______________________________________________
>> >>> Users mailing list
>> >>> Users at openlayers.org
>> >>> http://openlayers.org/mailman/listinfo/users
>> >> Christopher Schmidt
>> >> MetaCarta
>> >> Users mailing list
>> > Dash wrote:
>> >> I understand that you are probably trying to help me without words but
>> a
>> >> little more than just a link would help.  Believe me, I've removed
>> lines
>> >> of code and simplified everything I could.  I guess the next step
>> would
>> >> be to post the code.  Here is the init function I use when launching
>> the
>> >> page:
>> >> var map, layer, popup;
>> >> var markers, feature, marker;
>> >> function init() {
>> >> 	// Default map projection is ESPG:4326 -> WGS 84
>> >> 	// WGS 84 Bounds: -180.0000, -90.0000, 180.0000, 90.0000
>> >> 	map = new OpenLayers.Map('map');
>> >> 	// Initiate Map Controls
>> >> 	map.addControl(new OpenLayers.Control.LayerSwitcher());
>> >> 	map.addControl(new OpenLayers.Control.MousePosition());
>> >> 	// Create Google Layers
>> >> 	var gmap = new OpenLayers.Layer.Google("Google
>> Streets",{numZoomLevels:
>> >> 20});
>> >> 	var gphy = new OpenLayers.Layer.Google("Google Physical", {type:
>> >> G_PHYSICAL_MAP});
>> >>     var gsat = new OpenLayers.Layer.Google("Google Satellite",{type:
>> >> G_SATELLITE_MAP, numZoomLevels: 20});
>> >>     var ghyb = new OpenLayers.Layer.Google("Google Hybrid",{type:
>> >> G_HYBRID_MAP, numZoomLevels: 20});
>> >> 	// GML
>> >> 	var oc = new OpenLayers.Layer.GML("Box", "./textbox.xml");
>> >> 	// Add layers as an array
>> >> 	map.addLayers([gmap, gphy, gsat, ghyb, oc]);
>> >> 	// Zoom to the passed in bounds
>> >> 	//boundsExtent = new OpenLayers.Bounds(-180.0000, -90.0000, 180.0000,
>> >> 90.0000);
>> >> 	boundsExtent = new OpenLayers.Bounds(-123.562589253, 44.729986898,
>> >> -121.568458954, 45.918452947);
>> >> 	map.zoomToExtent(boundsExtent);
>> >> Here is the GML file that was created:
>> >> <?xml version="1.0" encoding="UTF-8"?>
>> >> <gml:FeatureCollection xmlns:gml="http://www.opengis.net/gml"
>> >> xmlns:xlink="http://www.w3.org/1999/xlink"
>> >> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> >> xmlns:fme="http://www.safe.com/gml/fme"
>> >> xsi:schemaLocation="http://www.safe.com/gml/fme textbox.xsd">
>> >> <gml:boundedBy>
>> >> <gml:Envelope srsName="EPSG:4326" srsDimension="2">
>> >> <gml:lowerCorner>45.3117814762066 -122.640406532134</gml:lowerCorner>
>> >> <gml:upperCorner>45.3820822372628 -122.536820512781</gml:upperCorner>
>> >> </gml:Envelope>
>> >> </gml:boundedBy>
>> >> <gml:featureMember>
>> >> <fme:testbox gml:id="iddfa35c96-59ff-4423-b062-668e3993b702">
>> >> <fme:FID>0</fme:FID>
>> >> <fme:Id>0</fme:Id>
>> >> <gml:surfaceProperty>
>> >> <gml:Surface srsName="EPSG:4326" srsDimension="2">
>> >> <gml:patches>
>> >> <gml:PolygonPatch>
>> >> <gml:exterior>
>> >> <gml:LinearRing>
>> >> <gml:posList>45.3117814762066 -122.640406532134 45.3820822372628
>> >> -122.640406532134 45.3819865899688 -122.536820512781 45.3117814762066
>> >> -122.538255222191 45.3117814762066 -122.640406532134</gml:posList>
>> >> </gml:LinearRing>
>> >> </gml:exterior>
>> >> </gml:PolygonPatch>
>> >> </gml:patches>
>> >> </gml:Surface>
>> >> </gml:surfaceProperty>
>> >> </fme:testbox>
>> >> </gml:featureMember>
>> >> </gml:FeatureCollection>
>> >> Is there something I am missing?  Any help would be greatly
>> appreciated.
>> View this message in context:
>> http://n2.nabble.com/GML-Overlay-tp3650992p3659138.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Christopher Schmidt
> MetaCarta
> Users mailing list
View this message in context: http://n2.nabble.com/GML-Overlay-tp3650992p3664658.html
