[OpenLayers-Users] GML Overlay
Christopher Schmidt crschmidt at metacarta.com
Thu Sep 17 18:34:54 EDT 2009
On Thu, Sep 17, 2009 at 11:10:07AM -0700, Dash wrote:
> Ok, I'm still stuck on this.  It seems that none of them work.  Could some
> review this to make sure that I'm doing it correctly?
This is not correct. Instead, format should be a *class* (not an instance):
  format: OpenLayers.Format.GML
-- Chris
> var gml = new OpenLayers.Layer.GML("GML", "./jlpts.gml");
> var gmlVector = new OpenLayers.Layer.Vector("GML", gml, {
> 	format: new OpenLayers.Format.GML(gml),
> 	formatOptions: {
> 		xy: false
> Christopher Schmidt-2 wrote:
> > On Wed, Sep 16, 2009 at 02:15:14PM -0700, Dash wrote:
> >> Well, I figured out the answer.  The Data Interop. Tool by ESRI outputs
> >> the
> >> coordinates in a lat / long format.  Well, OpenLayers and the GML file
> >> require the coordinates to be in a long / lat format.  What a pain in the
> >> butt!  Now, does anyone know how to fix that?
> > GML Format option: "xy: false"
> > So, in a Vector Layer:
> >  Vector("", "file.gml", {format: OpenLayers.Format.GML, formatOptions:
> > {xy: false}});
> > -- Chris
> >> >> On Tue, Sep 15, 2009 at 11:42:47AM -0700, Lugosi, Jim wrote:
> >> >>> I am trying to figure out how to use the GML overlay with OpenLayers.
> >> I
> >> >>> have searched high and low for examples and nothing seems to help.  I
> >> am
> >> >>> currently trying to convert a shapefile to a GML file using ESRI's
> >> Data
> >> >>> Interop. Tool.  I've used both the quick export and the Spatial ETL
> >> >>> Tool.  Everything seems to work, but when I try to display the
> >> >>> information on my map nothing shows up.  There are no JavaScript
> >> errors
> >> >>> and the layer shows up in my LayerSwitcher control so I really can't
> >> >>> tell what the problem is.  Also, I've dumbed down the process by
> >> >>> creating a shapefile of a box so that I don't have a large number of
> >> >>> coordinates.  Could someone please help with my dilemma?
> >> >> http://docs.openlayers.org/help/minimize.html
> >> >>> Thanks...
> >> >>> James Lugosi
> >> >>> Clackamas County - GISP
> >> >>> www.clackamas.us/gis
> >> >>> 503-723-4829
> >> >>> _______________________________________________
> >> >>> Users mailing list
> >> >>> Users at openlayers.org
> >> >>> http://openlayers.org/mailman/listinfo/users
> >> >> Christopher Schmidt
> >> >> MetaCarta
> >> >> Users mailing list
> >> > Dash wrote:
> >> >> I understand that you are probably trying to help me without words but
> >> a
> >> >> little more than just a link would help.  Believe me, I've removed
> >> lines
> >> >> of code and simplified everything I could.  I guess the next step
> >> would
> >> >> be to post the code.  Here is the init function I use when launching
> >> the
> >> >> page:
> >> >> var map, layer, popup;
> >> >> var markers, feature, marker;
> >> >> function init() {
> >> >> 	// Default map projection is ESPG:4326 -> WGS 84
> >> >> 	// WGS 84 Bounds: -180.0000, -90.0000, 180.0000, 90.0000
> >> >> 	map = new OpenLayers.Map('map');
> >> >> 	// Initiate Map Controls
> >> >> 	map.addControl(new OpenLayers.Control.LayerSwitcher());
> >> >> 	map.addControl(new OpenLayers.Control.MousePosition());
> >> >> 	// Create Google Layers
> >> >> 	var gmap = new OpenLayers.Layer.Google("Google
> >> Streets",{numZoomLevels:
> >> >> 20});
> >> >> 	var gphy = new OpenLayers.Layer.Google("Google Physical", {type:
> >> >> G_PHYSICAL_MAP});
> >> >>     var gsat = new OpenLayers.Layer.Google("Google Satellite",{type:
> >> >> G_SATELLITE_MAP, numZoomLevels: 20});
> >> >>     var ghyb = new OpenLayers.Layer.Google("Google Hybrid",{type:
> >> >> G_HYBRID_MAP, numZoomLevels: 20});
> >> >> 	// GML
> >> >> 	var oc = new OpenLayers.Layer.GML("Box", "./textbox.xml");
> >> >> 	// Add layers as an array
> >> >> 	map.addLayers([gmap, gphy, gsat, ghyb, oc]);
> >> >> 	// Zoom to the passed in bounds
> >> >> 	//boundsExtent = new OpenLayers.Bounds(-180.0000, -90.0000, 180.0000,
> >> >> 90.0000);
> >> >> 	boundsExtent = new OpenLayers.Bounds(-123.562589253, 44.729986898,
> >> >> -121.568458954, 45.918452947);
> >> >> 	map.zoomToExtent(boundsExtent);
> >> >> Here is the GML file that was created:
> >> >> <?xml version="1.0" encoding="UTF-8"?>
> >> >> <gml:FeatureCollection xmlns:gml="http://www.opengis.net/gml"
> >> >> xmlns:xlink="http://www.w3.org/1999/xlink"
> >> >> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> >> >> xmlns:fme="http://www.safe.com/gml/fme"
> >> >> xsi:schemaLocation="http://www.safe.com/gml/fme textbox.xsd">
> >> >> <gml:boundedBy>
> >> >> <gml:Envelope srsName="EPSG:4326" srsDimension="2">
> >> >> <gml:lowerCorner>45.3117814762066 -122.640406532134</gml:lowerCorner>
> >> >> <gml:upperCorner>45.3820822372628 -122.536820512781</gml:upperCorner>
> >> >> </gml:Envelope>
> >> >> </gml:boundedBy>
> >> >> <gml:featureMember>
> >> >> <fme:testbox gml:id="iddfa35c96-59ff-4423-b062-668e3993b702">
> >> >> <fme:FID>0</fme:FID>
> >> >> <fme:Id>0</fme:Id>
> >> >> <gml:surfaceProperty>
> >> >> <gml:Surface srsName="EPSG:4326" srsDimension="2">
> >> >> <gml:patches>
> >> >> <gml:PolygonPatch>
> >> >> <gml:exterior>
> >> >> <gml:LinearRing>
> >> >> <gml:posList>45.3117814762066 -122.640406532134 45.3820822372628
> >> >> -122.640406532134 45.3819865899688 -122.536820512781 45.3117814762066
> >> >> -122.538255222191 45.3117814762066 -122.640406532134</gml:posList>
> >> >> </gml:LinearRing>
> >> >> </gml:exterior>
> >> >> </gml:PolygonPatch>
> >> >> </gml:patches>
> >> >> </gml:Surface>
> >> >> </gml:surfaceProperty>
> >> >> </fme:testbox>
> >> >> </gml:featureMember>
> >> >> </gml:FeatureCollection>
> >> >> Is there something I am missing?  Any help would be greatly
> >> appreciated.
> >> View this message in context:
> >> http://n2.nabble.com/GML-Overlay-tp3650992p3659138.html
> >> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >> Users mailing list
> > Christopher Schmidt
> > MetaCarta
> > Users mailing list
> View this message in context: http://n2.nabble.com/GML-Overlay-tp3650992p3664658.html
> Users mailing list
Christopher Schmidt
MetaCarta
