[OpenLayers-Users] two different versions of docs
Bill Thoen bthoen at gisnet.com
Sun Sep 20 12:13:17 EDT 2009
P Kishor wrote:
> The only place where the above info is available to me is either the
> actual source file for WMSGetFeatureInfo, or [2a] or [2b].
> Once again, I ask, is there some better way, not obvious to me, I
> could have approached this so as to have an easier time discovering
> what I could or could not do to construct a proper constructor?
You'd be a great choice to help put together some documentation written
by users! What's been written is pretty good, but there's lot that still
needs writing and organizing.
But to answer your question(s), the differences between similar topics
are usually due to the fact that one set of documentation is written by
Natural Docs that scans the  comments in the header and builds a sort of
Reference Guide, vs. what's written by humans trying to provide a bit of
a Users Guide, of which is there's not much yet. What's most complete is
automatically generated and is more of a Users Reference, and there's
some gaps in that too. The difference being is that the Users guide
should tell you how to do high-level tasks like how to make a map from A
to Z, while the Users reference should give you the nuts and bolts
details about the functions mentioned by the other.
The closest thing to a Users Guide here is the List of Examples at
http://openlayers.org/dev/examples/ and some of the stuff under "Other
OpenLayers Documentation" at
http://trac.openlayers.org/wiki/Documentation, but the Examples need to
be cross-referenced by the function(s) they demonstrate and hyperlinked
to the appropriate page(s) of the natural docs. Also a relatively new
but good set of Users Guide documentation is the "Documentation" page at
http://docs.openlayers.org/, but that's not as complete yet as I'd like,
though probably that's one people should read first. All of these can be
found fairly easily by following the obvious links to "Documentation"
from the home page.
One area of hermetic knowledge that's often not known to new users is
the conventions used in building OpenLayers. These are probably so
second-nature to the developers by now that they don't realize what a
handicap not knowing these conventions is. In fact, knowing some of
these conventions obviates the need for documenting what would be
otherwise a rather long list.
One simple convention that's worth knowing is how the code modules are
named and organized in the source code library. If you know this one,
then it's very easy to find the source code files for  any object; just
change the dots in the object name to forward slashes and that becomes
the path to the source code file.
Most newbies find that one quickly enough, but a more subtle one is the
convention used to set displayClass names.  All objects that have a
displayClass property are set to the value  "ol" + class name + object
name, without the period delimiters and camelCased. For example
OpenLayers.Control.Panel would become olConotrolPanel. If it's an object
like a button that has different states you add ItemActive or
ItemInactive to the base, as in olControlDragPanItemActive, and if  it's
an object associated with an action, like a  cursor , you add Active to
the base, as in  olControlDragPanActive.  This convention may no big
deal to those who use it all the time, but once you realize it, the
frustrating problem of no documentation listing all these classes just
goes away!
Another one is the convention for passing an arbitrary list of
user-modified properties to an object's constructor. Not understanding
this one the newcomer can't believe such an obvious gap in the
documentation exists and  screams for documentation with a question like
"what are the !@#$% choices that go in the 'options' hashtable
parameter?" Actually that's fairly hard to document for each class
object because you'd have to repeat some of the properties over and over
(because they're inherited), or just write "see list of properties in
ancestor class.", which is sort what we get told now anyway. But all you
have to do to generate the list of these properties is to open the
source code for the function you're calling and note the classes it
inherits from; which are listed right there in the header after the
words "Inherits from". Then open that module and see where it inherits
from, and continue back until you get the original prototype. Finally,
with that list of classes, go to the Natural Docs pages for each class
and make a list of all properties from the origin function to the one
you're calling and that's your list of potential properties for the
"options" object. Who'd want to document that? Also, 90% of the
possibilities aren't relevant in any given situation, but knowing this
convention and what you need, you could easily determine the parameters
you need for the options without documentation.
Perhaps knowing the conventions of how classes are built in OpenLayers
would have helped  you to home in on your problem, but I think in this
case the root of your problem was more of a JavaScript one than an
OpenLayers one, and then it was further obfuscated by the fact that you
could specify the map parameter in more than one place, but only one
combination would actually work.
Finally, I'd like to suggest that if you're perceptive enough to analyze
the docs this closely that maybe you'd be interested in going just a bit
further.  I think what's needed to encourage users to contribute
documentation for things they've discovered that need more explanation
than what the docs provide now is a framework to provide a place for
little pieces of documentation. Where people might not want to take the
time to do something detailed and formal, they, might be willing to do
short and quickly. This could go in the wiki, linked to the general
Documentation page and eventually be incorporated in the official
documentation.
(sorry for writing a novel here this morning, but three cups of coffee
can cause loggorhea!)
- Bill Thoen
