[OpenLayers-Users] How Print openlayer Maps into pdf documents
Kris Geusebroek kgeusebroek at xebia.com
Thu Sep 24 08:05:30 EDT 2009
Hi salas,
You can ask your map for the current bbox. I believe its called getBounds() function.
Cheers Kris
Sent: Thursday, September 24, 2009 2:42 PM
To: Kris Geusebroek
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] How Print openlayer Maps into pdf documents
Thanks Kris, I find the example in geoserver but , how i can change the BBox dinamicaly in my code , for example when I zoom the region I need print this maps How I can make this ?
regards salas
	----- Original Message -----
	From: Kris Geusebroek <mailto:kgeusebroek at xebia.com>
	To: fsalas <mailto:fsalas at geocuba.cu>
	Sent: Thursday, September 24, 2009 1:35 AM
	Subject: RE: [OpenLayers-Users] How Print openlayer Maps into pdf documents
	Hi Salas,
	If you have a installation of geoserver you can find an example in the map preview demo section (just like the OpenLayers examples
	For example something like this (you need to change the bbox, srs and layer according to your data)
	http://localhost:8080/geoserver/wms?bbox=-14231.825,274059.86,305770.825,651904.14&styles=&Format=application/pdf&request=GetMap&version=1.1.1&layers=testLayer&width=516&height=550&srs=EPSG:28992
	Hope this helps.
	Remember that this will only allow you to generate pdf of layers you server with geoserver and not for example a google baselayer
	Cheers Kris
	Sent: Thursday, September 24, 2009 1:07 AM
	To: Kris Geusebroek
	Kris, Thanks, but I need an example of like make wms request with format application/pdf
	can you help me?
	regards Salas
	From: "Kris Geusebroek" <kgeusebroek at xebia.com <mailto:kgeusebroek at xebia.com> >
	To: "Alexandre Dube" <adube at mapgears.com <mailto:adube at mapgears.com> >; "fsalas" <fsalas at geocuba.cu <mailto:fsalas at geocuba.cu> >
	Cc: <users at openlayers.org <mailto:users at openlayers.org> >
	Sent: Wednesday, September 02, 2009 3:34 PM
	If you are using geoserver you can create a wms request with format application/pdf et volia!
	Cheers Kris
	-----Original Message-----
	From: users-bounces at openlayers.org <mailto:users-bounces at openlayers.org>  [mailto:users-bounces at openlayers.org] On Behalf Of Alexandre Dube
	Sent: Wednesday, September 02, 2009 5:29 PM
	To: fsalas
	Cc: users at openlayers.org <mailto:users at openlayers.org>
	  Did you read http://trac.openlayers.org/wiki/Printing <http://trac.openlayers.org/wiki/Printing>  ?
	  About eh ezpdf class extension, are you talking about this :
	http://www.ros.co.nz/pdf/ <http://www.ros.co.nz/pdf/>  ?  If so, that's the lib I used with
	phpMapScript to accomplish some printing, but it supports WMS only and I
	use Ext to make my form.  So take this example as a proof of concept
	only.  See at :
	    http://dev4.mapgears.com/wmsprint/ <http://dev4.mapgears.com/wmsprint/>
	  MapFish has a much more better printing tool and it supports Vector
	features printing.
	Best of luck,
	Alexandre
	fsalas wrote:
	> Hi all,
	> I'm trying to print the current image maps into pdf documents
	> using the  *EZPDF Class Extension,* but don´t work.
	> some body know how i cant implement this.
	> Thanks ,
	> salas
	> ___________________________________
	> Dirección de Comunicaciones
	> Grupo Empresarial GEOCUBA
	> Este mensaje esta libre de virus.
	> Revisado por Kaspersky Antivirus
	> Definition count: 2365875 Definition date: 8/11/2009 SecurityPlus
	> version: 3.0.5
	> Users mailing list
	> Users at openlayers.org <mailto:Users at openlayers.org>
	> http://openlayers.org/mailman/listinfo/users <http://openlayers.org/mailman/listinfo/users>
	Alexandre Dubé
	Mapgears
	www.mapgears.com <http://www.mapgears.com>
	Users mailing list
	Definition count: 2618974 Definition date: 9/23/2009 SecurityPlus version: 3.0.5
Definition count: 2645353 Definition date: 9/24/2009 SecurityPlus version: 3.0.5
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090924/31ea70d4/attachment.html
