[OpenLayers-Users] How Print openlayer Maps into pdf documents
fsalas fsalas at geocuba.cu
Thu Sep 24 10:42:30 EDT 2009
Hi, Kris,
I test with
  function Mostrar()
  alert(map.getBounds());
but there are error "map.getBounds() is not function", How I can implement this
regardas salas
  ----- Original Message -----
  To: fsalas
  Cc: users at openlayers.org
  Sent: Thursday, September 24, 2009 7:05 AM
  Subject: RE: [OpenLayers-Users] How Print openlayer Maps into pdf documents
  Hi salas,
  You can ask your map for the current bbox. I believe its called getBounds() function.
  Cheers Kris
  Sent: Thursday, September 24, 2009 2:42 PM
  To: Kris Geusebroek
  Subject: Re: [OpenLayers-Users] How Print openlayer Maps into pdf documents
  Thanks Kris, I find the example in geoserver but , how i can change the BBox dinamicaly in my code , for example when I zoom the region I need print this maps How I can make this ?
  regards salas
    To: fsalas
    Sent: Thursday, September 24, 2009 1:35 AM
    Hi Salas,
    If you have a installation of geoserver you can find an example in the map preview demo section (just like the OpenLayers examples
    For example something like this (you need to change the bbox, srs and layer according to your data)
    http://localhost:8080/geoserver/wms?bbox=-14231.825,274059.86,305770.825,651904.14&styles=&Format=application/pdf&request=GetMap&version=1.1.1&layers=testLayer&width=516&height=550&srs=EPSG:28992
    Hope this helps.
    Remember that this will only allow you to generate pdf of layers you server with geoserver and not for example a google baselayer
    Cheers Kris
    Sent: Thursday, September 24, 2009 1:07 AM
    To: Kris Geusebroek
    Kris, Thanks, but I need an example of like make wms request with format application/pdf
    can you help me?
    regards Salas
    To: "Alexandre Dube" <adube at mapgears.com>; "fsalas" <fsalas at geocuba.cu>
    Cc: <users at openlayers.org>
    Sent: Wednesday, September 02, 2009 3:34 PM
    If you are using geoserver you can create a wms request with format application/pdf et volia!
    Cheers Kris
    -----Original Message-----
    From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of Alexandre Dube
    Sent: Wednesday, September 02, 2009 5:29 PM
    To: fsalas
      Did you read http://trac.openlayers.org/wiki/Printing ?
      About eh ezpdf class extension, are you talking about this :
    http://www.ros.co.nz/pdf/ ?  If so, that's the lib I used with
    phpMapScript to accomplish some printing, but it supports WMS only and I
    use Ext to make my form.  So take this example as a proof of concept
    only.  See at :
        http://dev4.mapgears.com/wmsprint/
      MapFish has a much more better printing tool and it supports Vector
    features printing.
    Best of luck,
    Alexandre
    fsalas wrote:
    > Hi all,
    > I'm trying to print the current image maps into pdf documents
    > using the  *EZPDF Class Extension,* but don´t work.
    > some body know how i cant implement this.
    > Thanks ,
    > salas
    > ___________________________________
    > Dirección de Comunicaciones
    > Grupo Empresarial GEOCUBA
    > Este mensaje esta libre de virus.
    > Revisado por Kaspersky Antivirus
    > Definition count: 2365875 Definition date: 8/11/2009 SecurityPlus
    > version: 3.0.5
    > Users mailing list
    > Users at openlayers.org
    > http://openlayers.org/mailman/listinfo/users
    Alexandre Dubé
    Mapgears
    www.mapgears.com
    Users mailing list
    Definition count: 2618974 Definition date: 9/23/2009 SecurityPlus version: 3.0.5
  Definition count: 2645353 Definition date: 9/24/2009 SecurityPlus version: 3.0.5
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090924/74e6eb4f/attachment.html
