[OpenLayers-Users] How Print openlayer Maps into pdf documents
Kris Geusebroek kgeusebroek at xebia.com
Thu Sep 24 09:53:00 EDT 2009
Hi salas,
Sorry it's the function getExtent() you need.
You can find all available functions in the openlayers doc or source!
Cheers Kris
Sent: Thursday, September 24, 2009 4:43 PM
To: Kris Geusebroek
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] How Print openlayer Maps into pdf documents
Hi, Kris,
I test with
  function Mostrar()
  alert(map.getBounds());
but there are error "map.getBounds() is not function", How I can implement this
regardas salas
	----- Original Message -----
	From: Kris Geusebroek <mailto:kgeusebroek at xebia.com>
	To: fsalas <mailto:fsalas at geocuba.cu>
	Sent: Thursday, September 24, 2009 7:05 AM
	Subject: RE: [OpenLayers-Users] How Print openlayer Maps into pdf documents
	Hi salas,
	You can ask your map for the current bbox. I believe its called getBounds() function.
	Cheers Kris
	Sent: Thursday, September 24, 2009 2:42 PM
	To: Kris Geusebroek
	Thanks Kris, I find the example in geoserver but , how i can change the BBox dinamicaly in my code , for example when I zoom the region I need print this maps How I can make this ?
	regards salas
		Sent: Thursday, September 24, 2009 1:35 AM
		Hi Salas,
		If you have a installation of geoserver you can find an example in the map preview demo section (just like the OpenLayers examples
		For example something like this (you need to change the bbox, srs and layer according to your data)
		http://localhost:8080/geoserver/wms?bbox=-14231.825,274059.86,305770.825,651904.14&styles=&Format=application/pdf&request=GetMap&version=1.1.1&layers=testLayer&width=516&height=550&srs=EPSG:28992
		Hope this helps.
		Remember that this will only allow you to generate pdf of layers you server with geoserver and not for example a google baselayer
		Cheers Kris
		Sent: Thursday, September 24, 2009 1:07 AM
		To: Kris Geusebroek
		Kris, Thanks, but I need an example of like make wms request with format application/pdf
		can you help me?
		regards Salas
		From: "Kris Geusebroek" <kgeusebroek at xebia.com <mailto:kgeusebroek at xebia.com> >
		To: "Alexandre Dube" <adube at mapgears.com <mailto:adube at mapgears.com> >; "fsalas" <fsalas at geocuba.cu <mailto:fsalas at geocuba.cu> >
		Cc: <users at openlayers.org <mailto:users at openlayers.org> >
		Sent: Wednesday, September 02, 2009 3:34 PM
		If you are using geoserver you can create a wms request with format application/pdf et volia!
		Cheers Kris
		-----Original Message-----
		From: users-bounces at openlayers.org <mailto:users-bounces at openlayers.org>  [mailto:users-bounces at openlayers.org] On Behalf Of Alexandre Dube
		Sent: Wednesday, September 02, 2009 5:29 PM
		To: fsalas
		Cc: users at openlayers.org <mailto:users at openlayers.org>
		  Did you read http://trac.openlayers.org/wiki/Printing <http://trac.openlayers.org/wiki/Printing>  ?
		  About eh ezpdf class extension, are you talking about this :
		http://www.ros.co.nz/pdf/ <http://www.ros.co.nz/pdf/>  ?  If so, that's the lib I used with
		phpMapScript to accomplish some printing, but it supports WMS only and I
		use Ext to make my form.  So take this example as a proof of concept
		only.  See at :
		    http://dev4.mapgears.com/wmsprint/ <http://dev4.mapgears.com/wmsprint/>
		  MapFish has a much more better printing tool and it supports Vector
		features printing.
		Best of luck,
		Alexandre
		fsalas wrote:
		> Hi all,
		> I'm trying to print the current image maps into pdf documents
		> using the  *EZPDF Class Extension,* but don´t work.
		> some body know how i cant implement this.
		> Thanks ,
		> salas
		> ___________________________________
		> Dirección de Comunicaciones
		> Grupo Empresarial GEOCUBA
		> Este mensaje esta libre de virus.
		> Revisado por Kaspersky Antivirus
		> Definition count: 2365875 Definition date: 8/11/2009 SecurityPlus
		> version: 3.0.5
		> Users mailing list
		> Users at openlayers.org <mailto:Users at openlayers.org>
		> http://openlayers.org/mailman/listinfo/users <http://openlayers.org/mailman/listinfo/users>
		Alexandre Dubé
		Mapgears
		www.mapgears.com <http://www.mapgears.com>
		Users mailing list
		Definition count: 2618974 Definition date: 9/23/2009 SecurityPlus version: 3.0.5
	Definition count: 2645353 Definition date: 9/24/2009 SecurityPlus version: 3.0.5
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090924/e6979d5c/attachment.html
