[OpenLayers-Users] Kml problems 2
Duncan Sayers duncansayers at threefivesouth.net
Wed Sep 30 08:09:09 EDT 2009
I ran your original file through a local copy of the KML Parser
Example that you can find here:
http://openlayers.org/dev/examples/KMLParser.html
There's a bit in the resulting page that shows:
Feature: Geometry: null
Then after paring your kml back to that shown below I  got what seems
correct, namely:
Feature: Geometry: POINT(1.2292789482351385 42.12505809906476),
<?xml version="1.0" encoding="UTF-8"?><kml xmlns="http://earth.google.com/kml/2.0
    <Document>
     <name>ICC - Fulls 1:25.000</name>
                 <Folder id="layer 0">
                                <name>Tall 1:25.000</name>
       <Placemark>
          <name><![CDATA[67-23]]></name>
             <Point>
                <coordinates>1.2292789482351385,42.12505809906476</
coordinates>
             </Point>
       </Placemark>
       <Placemark>
          <name><![CDATA[68-19]]></name>
             <Point>
                <coordinates>1.3959550858972396,42.458391895861894</
coordinates>
             </Point>
       </Placemark>
                 </Folder>
    </Document>
</kml>
On 30/09/2009, at 9:29 PM, Vidal, Antoni wrote:
> Hello,
> I've deleted one of two features from every <Placemark>, but new kml
> doesn't work.
> Maybe is a bug of KML.js?
> Thank's.
> Antoni Vidal
> Unitat d'Aplicacions SIG-WEB
> Institut Cartogràfic de Catalunya
> Parc de Montjuïc, E-08038 Barcelona
> Tel. (+34) 93 567 15 00 (ext. 3228)
> www.icc.cat
> Message: 3
> Date: Wed, 30 Sep 2009 21:03:08 +0930
> From: Duncan Sayers <duncansayers at threefivesouth.net>
> Subject: Re: [OpenLayers-Users] Kml problems 2
> To: OpenLayers Users <users at openlayers.org>
> Message-ID: <D8674DDD-D18D-42E0-BB24-B1B54209EE1B at threefivesouth.net>
> Content-Type: text/plain; charset=windows-1252; format=flowed;
> 	delsp=yes
> In lib/OpenLayers/Format/KML.js there is a comment in the method
> parseFeature that says:
> // only accept one geometry per feature - look for highest "order"
> I wonder if this "one geometry per feature" bit is holding you up.
> On 30/09/2009, at 7:51 PM, Vidal, Antoni wrote:
>> Hello list,
>> I have a kml file with two Placemark with a point and a polygon each
>> one, but only the last is showed over the map.
>>   <Document>
>>      <Placemark>
>>         <MultiGeometry>
>>            <Point>
>> coordinates>
>>            </Point>
>>            <Polygon>
>>               <outerBoundaryIs>
>>                  <LinearRing>
>>                     <coordinates decimal="." cs="," ts="
>> ">1.31261326,42.16672373 1.14594315,42.16672487
>> 1.14594468,42.08339244 1.31261474,42.08339135
>> 1.31261326,42.16672373</coordinates>
>>                  </LinearRing>
>>               </outerBoundaryIs>
>>            </Polygon>
>>            </MultiGeometry>
>>      </Placemark>
>>      <Placemark>
>>         <MultiGeometry>
>>            <Point>
>> coordinates>
>>            </Point>
>>            <Polygon>
>>               <outerBoundaryIs>
>>                  <LinearRing>
>> ">1.47929122,42.50006088 1.31261965,42.5000564 1.31261912,42.4167232
>> 1.47928988,42.41672697 1.47929122,42.50006088</coordinates>
>>                  </LinearRing>
>>               </outerBoundaryIs>
>>            </Polygon>
>>            </MultiGeometry>
>>      </Placemark>
>>                </Folder>
>>   </Document>
>> </kml>
>> Any idea why the first Placemark isn?t rendered over the map?
>> Thank?s.
>> Antoni Vidal
>> Institut Cartogr?fic de Catalunya
>> Parc de Montju?c, E-08038 Barcelona
>> www.icc.cat
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Message: 4
> Date: Wed, 30 Sep 2009 13:43:22 +0200
> From: "Rahn Hanno (rahn)" <rahn at zhaw.ch>
> Subject: [OpenLayers-Users] TileCache and Openlayers
> To: <users at openlayers.org>
> Message-ID:
> 	<3F643797A078EB4FB0288008096809840186943B at langouste.zhaw.ch>
> Content-Type: text/plain; charset="iso-8859-1"
> I will realise the Tilecache but it doesn't work with my base layer.
> For all other layers it works.
> Hello list,
> I have another question and perhaps somebody can help me. I try to
> use Tilecache for a better performance of my maps.
> I try to realise it, but in this time it will only work for my
> background layers. For my base Layer it doesn^t work.
> For my base layer (only polygons, "gemeinden_2008") I write the
> follwing code in the tilecache.cfg.
> [gemeinden_2008]
> type=WMS
> url=http://webgis.hsw.ch/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/
> htdocs/GINES/Maps/Gemeinden_Bern.map
> mapfile=C:/ms4w/Apache/htdocs/GINES/Maps/Gemeinden_Bern.map
> layers=gemeinden_2008
> extension=png
> extent_type=loose
> srs=EPSG:21781
> bbox=555100,129900,678450,245000
> metaTile=true
> And in my OpenLayers File I define the layer like this:
> var layerName = (jahr <=2008) ? 'gemeinden_2008' : 'gemeinden_2009';
> var urlArrayTC = ["http://webgis.hsw.ch/cgi-bin/tilecache/tilecache.cgi?
> var mapFile = "../htdocs/GINES/Maps/Gemeinden_Bern.map";
> var options1 = {
>                        maxExtent: new OpenLayers.Bounds
> (555100,129900,678450,245000),
>                        maxScale: '500',
>                        minScale: '458262',
>                        //                      fractionalZoom: true,
>                        resolutions:[481.8359375, 240.91796875,
> 120.458984375, 60.2294921875, 30.11474609375, 15.057373046875,
> 7.5286865234375, 3.76434326171875, 1.882171630859375,
> 0.9410858154296875, 0.47054290771484375, 0.23527145385742188,
> 0.11763572692871094, 0.058817863464355469, 0.029408931732177734,
> 0.014704465866088867, 0.0073522329330444336, 0.0036761164665222168,
> 0.0018380582332611084, 0.0009190291166305542],
>                        //                      tileSize: new
> OpenLayers.Size(500,500),
>                        units: 'm',
>                        projection: "EPSG:21781",
>                        controls: []
> var map = new OpenLayers.Map('map',options1);
> var wms = new OpenLayers.Layer.WMS("Gemeinden",urlArrayTC,
> {map:mapFile,layers:layerName,format:"image/
> png",EXCEPTIONS:"application/vnd.ogc.se_inimage"} );
> var sld_string=url+"jahr="+jahr
> +"&indikator="+indikator1+"&klassen="+klassen+"&vis="+vis
> +"&fusion="+jahr4+"&farbe="+farbe;
> wms.mergeNewParams({ SLD:sld_string});
> I only get a white map without any polygons. Perhaps you can give me
> a little tip. I don't know Why I have no map data.
> A lot of thanks
> Hanno Rahn
> Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
> ZHAW Z?rcher Hochschule f?r Angewandte Wissenschaften Umwelt und Nat?
> rliche Ressourcen
> Fachstelle Geoinformatik
> Gr?ental, Postfach CH-8820 W?denswil
> Tel +41 (0)58 934 5592
> Fax +41 (0)58 934 5580
> hanno.rahn at zhaw.ch
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://openlayers.org/pipermail/users/attachments/20090930/dca0fbf1/attachment.htm
> Users mailing list
> End of Users Digest, Vol 36, Issue 105
