[OpenLayers-Users] Is it possible to have an OverviewMap for a vector layer?
Bart van den Eijnden bartvde at osgis.nl
Tue Apr 6 22:17:22 EDT 2010
If you just leave out the layers parameter alltogether, the overview map will by default clone the baselayer of your map.
Best regards,
Bart
On Apr 6, 2010, at 9:13 PM, sasamil wrote:
> I had a lot of troubles with this, too.
> IMHO the problem exists regardless of the layer type (it can be vector, wms,
> wfs,... whatsoever).
> As I remember the point is to use baselayer.clone() instead of baselayer and
> the scale of overview should be carefully set in the options (ovOptions in
> my example code). It is also possible to incorporate more than one layer in
> overview, but the first one need to be a baselayer.
> This is a piece of my code that works!
>    var ovOptions = {
> 				maxExtent: new OpenLayers.Bounds(7380500, 4670500, 7670500, 4960500),
> 				units: 'm',
> 				projection: new OpenLayers.Projection("EPSG:31277"),
> 				scales: [1700000]
>    var overview = new OpenLayers.Control.OverviewMap({layers:
> [baselayer.clone(), layer_ovode, layer_ogradovi], mapOptions: ovOptions});
>    map.addControl(overview);
> View this message in context: http://n2.nabble.com/Is-it-possible-to-have-an-OverviewMap-for-a-vector-layer-tp4855411p4860757.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
