[OpenLayers-Users] Map background
christopher.schmidt at nokia.com
Sun Aug 22 21:11:15 EDT 2010
On Aug 22, 2010, at 8:59 PM, ext Kalyan Kamepalli wrote:
> Hello everyone,
> Is any one using OpenLayers on IE 6 ? I have a problem here. I initially developed a project with OpenLayers on IE8 and everything looks pretty and in place ( Like the forms creation, Controls CSS ). I now, have to shift this development to IE6 and unfortunately the whole projects seems dim. Most of the DOM elements, CSS are not working as they did in IE8. Most of the background of Map turned to be a light blue colour in IE6 from white in IE8.
> Is there any way to change this back to White in IE6 ? What CSS class should I check in to set this ? Are there different classes for different browsers ?? Why is it showing two different colours on two versions ?
IE6 does not support alpha-transparent PNGs; you will need to either use
another image format, or not use transparent images. It is possible,
if this is on the baselayer of your map, that simply changing our output
from RGBA to RGB might solve this problem.
-- Chris
> Any ideas and experiences with IE6 & OL ??
> Cheers,
> Kalyan
> <ATT00001..txt>
