[OpenLayers-Users] Google Overviewmap
JuKiM rifins at gmail.com
Fri Feb 5 13:06:51 EST 2010
Maybe this is why is not shown correctly the overview..
http://trac.openlayers.org/ticket/1050
<http://trac.openlayers.org/ticket/1050>Thanks.
2010/2/5 JuKiM <rifins at gmail.com>
> The only thing that changes with overview.maximizeControl(); is that the
> square that indicates the visible zone of the base layer in the overview map
> is centered in the overview's map, but I think that the real center of the
> base layer, is still in the top left of the overview...
> Any ideas?
> It doesn't works for me..
>> For a high zoom level, the center of the base layer and the center of the
>> overview are very similar, but as I got lower zoom levels and showing more
>> map, it seems like the center of the base layer is more to the north-west
>> than the center of the overview.. And in each refresh of overview map zoom
>> level the diference between both centers increases..
>> Can be a problem with projections maybe?
>> Thanks!
>> 2010/2/5 Max Weidemann <max.weidemann at freenet.de>
>>> I think it is a bug in Openlayers. I described it here
>>> if you call the maximizeControl Function after you add the Control and
>>> set
>>> spherical Mercator to true it will work.
>>> map.addControl(overview);
>>> View this message in context:
>>> http://n2.nabble.com/Google-Overviewmap-tp4519147p4520026.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100205/3af1fd1f/attachment.html
