[OpenLayers-Users] Selectfeature not firing
Chris Green chris.green at ibstv.co.uk
Fri Feb 26 06:48:24 EST 2010
Hi Alex
I finally figured out what seems to be happening. When I create a vector layer and populate it with features as follows...
var wfs = new OpenLayers.Layer.Vector("Countries WFS", {
	styleMap: styleMap2,
	strategies: [new OpenLayers.Strategy.BBOX()],
	protocol: new OpenLayers.Protocol.WFS({
	url:"http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/apps/OLFurtherTest/htdocs/wfsVectorGetFeature.map",
	featureType: "France",
	featureNS: "http://mapserver.gis.umn.edu/mapserver"})
map.addLayer(wfs)
....then any features which are added are not selectable by SelectFeature. If on the other hand I create a blank vector layer and add features to it by making a separate WFS call and using Vector.addFeatures(WFSfeatures); then those features can be selected by the SelectFeature control.
I can make my map using this second method but it seems more cumbersome and I wonder if I am missing something in the first method....it seems that when I create a vector layer with in-built WFS call as above then the resulting layer is not editable. Does this make sense and do you have any suggestions?
Best regards,
Chris
-----Original Message-----
From: Alexandre Dube [mailto:adube at mapgears.com]
Sent: 24 February 2010 21:55
To: chris.green at ibstv.co.uk
Cc: Users at openlayers.org
Subject: Re: [OpenLayers-Users] Selectfeature not firing
Chris,
What you're describing is a normal behavior when the Navigation and
SelectFeature control are both activated, yes. To resolve this, you could :
* have a toolbar with your controls as buttons and only one is active at
a time
* have your SelectFeature control clicks work only while pressing a
specific key (ctrl for example). This could be done by defining a
'keymask' to the Handler.Feature object of your SF control.
* make the "select" on "hover" instead of "click", see an example [1]
Hope this helps,
Alexandre
[1] http://openlayers.org/dev/examples/highlight-feature.html
Chris Green wrote:
> Alex
> Can't really offer much more except that I observe that if I comment out
> selectCtrl.activate(); then I can drag the map to a new position when the
> cursor is over the feature on the vector layer delivered by WFS, but if the
> selectctrl is activated then dragging the map does not work when the cursor
> is in that position (but it does work if the cursor is anywhere else on the
> map). So there seems to be some kind of conflict caused by this control.
> Does this help?
> Regards,
> Chris
> Sent: 24 February 2010 15:47
> Chris,
> Could you share a live example or more code demonstrating your problem ?
> The code you pasted below doesn't seem to have any issue.
> Kind regards,
> Alexandre
> Chris Green wrote:
>> Hello all
>> Hope someone can help with what is probably a simple problem that I
>> don’t seem to be able to solve. I have created a vector layer which
>> has features taken from a wms layer:
>> url:
>> map.addLayer(wfs);
>> This works OK, but I want to be able to click to select an individual
>> feature so I added:
>> var selectCtrl = new OpenLayers.Control.SelectFeature(wfs,
>> {clickout: true}
>> map.addControl(selectCtrl);
>> However the selectfeature control does not fire in response to any map
>> clicks. Can anyone suggest what I am missing?
>> Chris
>> Users mailing list
>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
