[OpenLayers-Users] OpenLayers.loadURL not working
Barend Köbben kobben at itc.nl
Wed Jan 6 09:05:58 EST 2010
This sounds very much like a JavaScript sandbox security problem. JavaScript
(so also OpenLayers), is not allowed to fetch data from a domain other then
where it originated from. So if you get a file with openlayers script from
www.mysite.com and try to do a loadURL in it from www.somewherelse.com it
will not work. IE has a setting to override this security (which in general
is a bad idea), but FF hasn't .
If this is your case, you'll need a proxy server/script (search fro that in
the OpenLayers Docs).
Barend Köbben
Senior Lecturer
University of Twente, Faculty of Geo-Information Science and
Earth Observation (ITC)
PO Box 6, 7500AA Enschede, The Netherlands
+31 (0)53 4874253
On 06-01-10 14:05, "ManuNea" <manunea at hotmail.com> wrote:
> Hi,
> i having same troubles. But recently, i use IE to try the page javascript
> and found that it's work perfectly on IE. No data, in other hand, are
> display under firefox.
> I analyse network trafic and check that OpenLayer under firefox send and
> receive data from my WMS Server, but those data are never accessible.
> An idea ?
> I'm using firefox 3.5.6, and IE 8.0.
> Ivan Grcic-2 wrote:
>> On Sat, Jul 11, 2009 at 1:52 PM, Simo D <simone.dalmasso at gmail.com> wrote:
>>> Hi, the server is the same but on another port. I think it should work in
>>> this way.
>> Nope, it wont. You need a proxy.
>> Cheers
>> I use firebug and I inspected all the code with brakepoints but I
>>> get no errors. In the page that I build is also present ext.js but I
>>> don't
>>> use id to do the ajax request. On the server side the application runs
>>> under
>>> django but also this shouldn't be an issue. Analysing the server response
>>> I
>>> see that is correct (200 status code) but empty.
>>> It's strange because on other applications it works fine.
>>> Thanks.
>>> Simone.
>>> Till Adams wrote:
>>>> Simo,
>>>> is the WMS you are requesting from another server?
>>>> In this case, you should use the OL proxy-host to prevent from
>>>> cross-scriptuing errors,
>>>> Till
>>>>> Hi list, I'm using this function "OpenLayers.loadURL(url, '', this,
>>>>> setResponse, setResponse);" to make an getFeatureInfo on geoserver. my
>>>>> url
>>>>> variable is:
>>>>> "var url =  map.layers[2].getFullRequestString(
>>>>>                              REQUEST: "GetFeatureInfo",
>>>>>                              EXCEPTIONS: "application/vnd.ogc.se_xml",
>>>>>                              BBOX: map.getExtent().toBBOX(),
>>>>>                              X: e.xy.x,
>>>>>                              Y: e.xy.y,
>>>>>                              INFO_FORMAT: 'text/plain',
>>>>>                              QUERY_LAYERS: map.layers[2].params.LAYERS,
>>>>>                              FEATURE_COUNT: 1,
>>>>>                              srs: 'EPSG:900913',
>>>>>                              layers: 'layer',
>>>>>                              styles: '',
>>>>>                              WIDTH: map.size.w,
>>>>>                              HEIGHT: map.size.h
>>>>> The query returns an empty response (looking through firebug) but if I
>>>>> copy
>>>>> che address in the browser bar, the response is ok.
>>>>> Have you got any ideas?
>>>>> Thanks in avdance.
>>>>> Simone.
>>>> terrestris GmbH & Co. KG
>>>> Irmintrudisstrasse 17
>>>> 53111 Bonn
>>>> Germany
>>>> Till Adams
>>>> Geschäftsführung
>>>> Tel: +49 (0)228 / 962 899-52
>>>> Fax: +49 (0)228 / 962 899-57
>>>> adams at terrestris.de http://www.terrestris.de
>>>> Amtsgericht Bonn, HRA 6835
>>>> Komplementärin:
>>>> terrestris Verwaltungs GmbH
>>>> vertreten durch:
>>>> Hinrich Paulsen, Till Adams
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> View this message in context:
>>> http://n2.nabble.com/OpenLayers.loadURL-not-working-tp3236300p3242326.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>> Ivan Grcic
>> Users mailing list
> Emmanuel REUTER
> Centre Informatique de Recherche
> Ingénieur "Réseaux non mutualisables"
> INRETS  - 25, Avenue François Mitterrand - Case 24 - 69675 BRON CEDEX
> Tél. : (+33) 04.72.14.25.54 (poste 25.54)
> http://n2.nabble.com/OpenLayers-loadURL-not-working-tp3236300p4260519.html
> Users mailing list
Faculty of Geo-Information Science and Earth Observation (ITC)
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
