[OpenLayers-Users] OpenLayers.loadURL not working
ManuNea manunea at hotmail.com
Wed Jan 6 09:08:51 EST 2010
all my layers are located onto the same WMS server. I'll try to find a way
with a proxy/server script in order to find if it could works properly.
Emmanuel REUTER
Centre Informatique de Recherche
Ingénieur "Réseaux non mutualisables"
INRETS  - 25, Avenue François Mitterrand - Case 24 - 69675 BRON CEDEX
Tél. : (+33) 04.72.14.25.54 (poste 25.54)
Barend Kobben wrote:
> This sounds very much like a JavaScript sandbox security problem.
> JavaScript
> (so also OpenLayers), is not allowed to fetch data from a domain other
> then
> where it originated from. So if you get a file with openlayers script from
> www.mysite.com and try to do a loadURL in it from www.somewherelse.com it
> will not work. IE has a setting to override this security (which in
> general
> is a bad idea), but FF hasn't .
> If this is your case, you'll need a proxy server/script (search fro that
> in
> the OpenLayers Docs).
> Barend Köbben
> Senior Lecturer
> University of Twente, Faculty of Geo-Information Science and
> Earth Observation (ITC)
> PO Box 6, 7500AA Enschede, The Netherlands
> +31 (0)53 4874253
> On 06-01-10 14:05, "ManuNea" <manunea at hotmail.com> wrote:
>> Hi,
>> i having same troubles. But recently, i use IE to try the page javascript
>> and found that it's work perfectly on IE. No data, in other hand, are
>> display under firefox.
>> I analyse network trafic and check that OpenLayer under firefox send and
>> receive data from my WMS Server, but those data are never accessible.
>> An idea ?
>> I'm using firefox 3.5.6, and IE 8.0.
>> Ivan Grcic-2 wrote:
>>> On Sat, Jul 11, 2009 at 1:52 PM, Simo D <simone.dalmasso at gmail.com>
>>> wrote:
>>>> Hi, the server is the same but on another port. I think it should work
>>>> in
>>>> this way.
>>> Nope, it wont. You need a proxy.
>>> Cheers
>>> I use firebug and I inspected all the code with brakepoints but I
>>>> get no errors. In the page that I build is also present ext.js but I
>>>> don't
>>>> use id to do the ajax request. On the server side the application runs
>>>> under
>>>> django but also this shouldn't be an issue. Analysing the server
>>>> response
>>>> I
>>>> see that is correct (200 status code) but empty.
>>>> It's strange because on other applications it works fine.
>>>> Thanks.
>>>> Simone.
>>>> Till Adams wrote:
>>>>> Simo,
>>>>> is the WMS you are requesting from another server?
>>>>> In this case, you should use the OL proxy-host to prevent from
>>>>> cross-scriptuing errors,
>>>>> Till
>>>>>> Hi list, I'm using this function "OpenLayers.loadURL(url, '', this,
>>>>>> setResponse, setResponse);" to make an getFeatureInfo on geoserver.
>>>>>> my
>>>>>> url
>>>>>> variable is:
>>>>>> "var url =  map.layers[2].getFullRequestString(
>>>>>>                              REQUEST: "GetFeatureInfo",
>>>>>>                              EXCEPTIONS:
>>>>>> "application/vnd.ogc.se_xml",
>>>>>>                              BBOX: map.getExtent().toBBOX(),
>>>>>>                              X: e.xy.x,
>>>>>>                              Y: e.xy.y,
>>>>>>                              INFO_FORMAT: 'text/plain',
>>>>>>                              QUERY_LAYERS:
>>>>>> map.layers[2].params.LAYERS,
>>>>>>                              FEATURE_COUNT: 1,
>>>>>>                              srs: 'EPSG:900913',
>>>>>>                              layers: 'layer',
>>>>>>                              styles: '',
>>>>>>                              WIDTH: map.size.w,
>>>>>>                              HEIGHT: map.size.h
>>>>>> The query returns an empty response (looking through firebug) but if
>>>>>> I
>>>>>> copy
>>>>>> che address in the browser bar, the response is ok.
>>>>>> Have you got any ideas?
>>>>>> Thanks in avdance.
>>>>>> Simone.
>>>>> terrestris GmbH & Co. KG
>>>>> Irmintrudisstrasse 17
>>>>> 53111 Bonn
>>>>> Germany
>>>>> Till Adams
>>>>> Geschäftsführung
>>>>> Tel: +49 (0)228 / 962 899-52
>>>>> Fax: +49 (0)228 / 962 899-57
>>>>> adams at terrestris.de http://www.terrestris.de
>>>>> Amtsgericht Bonn, HRA 6835
>>>>> Komplementärin:
>>>>> terrestris Verwaltungs GmbH
>>>>> vertreten durch:
>>>>> Hinrich Paulsen, Till Adams
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
>>>> View this message in context:
>>>> http://n2.nabble.com/OpenLayers.loadURL-not-working-tp3236300p3242326.html
>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>> Users mailing list
>>> Ivan Grcic
>>> Users mailing list
>> Emmanuel REUTER
>> http://n2.nabble.com/OpenLayers-loadURL-not-working-tp3236300p4260519.html
>> Users mailing list
> Faculty of Geo-Information Science and Earth Observation (ITC)
> E-mail disclaimer
> The information in this e-mail, including any attachments, is intended for
> the addressee only. If you are not the intended recipient, you are hereby
> notified that any disclosure, copying, distribution or action in relation
> to the content of this information is strictly prohibited. If you have
> received this e-mail by mistake, please delete the message and any
> attachment and inform the sender by return e-mail. ITC accepts no
> liability for any error or omission in the message content or for damage
> of any kind that may arise as a result of e-mail transmission.
> Users mailing list
View this message in context: http://n2.nabble.com/OpenLayers-loadURL-not-working-tp3236300p4260805.html
