[OpenLayers-Users] Button Active CSS Styling
Henry Rotzoll henry.rotzoll at dlr.de
Thu Jan 7 12:06:19 EST 2010
I just need a button that can be "turned on", i. e. the users sees that the
function it fulfills is active.
So the user clicks on the button --> its appearance changes --> the user can
draw a feature (function of the button). After the drawing, the button is
deactivated to its original state.
Maybe a toggle button would be better in my case?
Bye Henry
Eric Lemoine-2-2 wrote:
> On Thursday, January 7, 2010, Henry Rotzoll <henry.rotzoll at dlr.de> wrote:
>> Thanks Kris!
>> "btn.activate();" did the trick!
> Your control is a button as opposed to a toggle, and it's not active
> by default its DOM element gets "Inactive" class. When you activate it
> gets the "Active" class, so it's rendering changes. I don't understand
> why you need two classes and two ways to render the button.
> Cheers,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Button-Active-CSS-Styling-tp4266755p4267552.html
