[OpenLayers-Users] Trying to draw a box on a map, and get the coordinates back.
Jtrsmith jtrsmith at gmail.com
Thu Jan 7 13:36:29 EST 2010
thank you that works.
is it possible to get the vertices in a geojson coordinate format?
i.e.
[-277, 359], [-277, 407], [-238, 407], [-238, 359], [-277, 359]
instead of
POINT(-277 359),POINT(-277 407),POINT(-238 407),POINT(-238 359)
thanks again
John
Arnd Wippermann wrote:
> Hi,
> That should it be.
> function findcoords (event) {
>      var vertices = event.feature.geometry.getVertices();
>      alert('ID:' + vertices);
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Jtrsmith
> Gesendet: Donnerstag, 7. Januar 2010 17:27
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Trying to draw a box on a map, and get the
> coordinates back.
> i am not sure i explained what i was looking for correctly. here is an
> example.
> vectors.events.register('featureadded', vectors, findcoords); function
> findcoords (feature) {
>      var vertices = feature.geometry.getVertices();
>      document.getElementById('output').value = 'ID:' + vertices; }
> the event does actually trigger, however, feature.geometry.getVertices()
> does not work.
> i am using geojson to display other polygons on the map, and would like
> the
> variable vertices to get the coordinates of the polygon vertices so that i
> can add a new polygon to the map and save the coordinates in a database.
> John
> micklesh wrote:
>> Hi, John.
>> if i understood your requirements, there is an example in the docs
>> http://dev.openlayers.org/docs/files/OpenLayers/Control-js.html
>> regards, michael.
>> 2010/1/4 John Smith <jtrsmith at gmail.com>
>>> i just saw this post and was wondering if the solution was ever
>>> found. i am basically trying to do the same thing. I need to draw a
>>> box around an area of my map and show the coordinates in a form
>>> field, so i can post the coordinates and a description to my
>>> database.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> http://n2.nabble.com/Trying-to-draw-a-box-on-a-map-and-get-the-coordinates-b
> ack-tp4251287p4267311.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users mailing list
View this message in context: http://n2.nabble.com/Trying-to-draw-a-box-on-a-map-and-get-the-coordinates-back-tp4251287p4268014.html
