[OpenLayers-Users] Trying to draw a box on a map, and get the coordinates back.
Arnd Wippermann arnd.wippermann at web.de
Thu Jan 7 16:55:06 EST 2010
Hi John,
To get geoJSON in return use OpenLayers.Format.GeoJSON():
var formats = {
    wkt:     new OpenLayers.Format.WKT(),
    geojson: new OpenLayers.Format.GeoJSON(),
    georss:  new OpenLayers.Format.GeoRSS(),
    gml:     new OpenLayers.Format.GML(),
    kml:     new OpenLayers.Format.KML()
var type = "geojson";
//var type = "gml";
var theParser = formats[type];
function findcoords (event) {
    var data = theParser.write(event.feature);
    alert('ID:' + data);
    //only relevant for geoJSON, and only one feature
    var objData = eval ( '(' + data + ')');
    alert(objData["geometry"]["coordinates"]);
vectors.events.register('featureadded', vectors, findcoords);
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Jtrsmith
Gesendet: Donnerstag, 7. Januar 2010 19:36
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Trying to draw a box on a map, and get the
coordinates back.
thank you that works.
is it possible to get the vertices in a geojson coordinate format?
i.e.
[-277, 359], [-277, 407], [-238, 407], [-238, 359], [-277, 359]
instead of
POINT(-277 359),POINT(-277 407),POINT(-238 407),POINT(-238 359)
thanks again
John
Arnd Wippermann wrote:
> Hi,
> That should it be.
>      var vertices = event.feature.geometry.getVertices();
>      alert('ID:' + vertices);
> Arnd
> [mailto:users-bounces at openlayers.org] Im Auftrag von Jtrsmith
> Gesendet: Donnerstag, 7. Januar 2010 17:27
> i am not sure i explained what i was looking for correctly. here is an
> example.
> vectors.events.register('featureadded', vectors, findcoords); function
> findcoords (feature) {
>      var vertices = feature.geometry.getVertices();
>      document.getElementById('output').value = 'ID:' + vertices; }
> the event does actually trigger, however,
> feature.geometry.getVertices() does not work.
> i am using geojson to display other polygons on the map, and would
> like the variable vertices to get the coordinates of the polygon
> vertices so that i can add a new polygon to the map and save the
> coordinates in a database.
> John
> micklesh wrote:
>> Hi, John.
>> if i understood your requirements, there is an example in the docs
>> http://dev.openlayers.org/docs/files/OpenLayers/Control-js.html
>> regards, michael.
>> 2010/1/4 John Smith <jtrsmith at gmail.com>
>>> i just saw this post and was wondering if the solution was ever
>>> found. i am basically trying to do the same thing. I need to draw a
>>> box around an area of my map and show the coordinates in a form
>>> field, so i can post the coordinates and a description to my
>>> database.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> http://n2.nabble.com/Trying-to-draw-a-box-on-a-map-and-get-the-coordin
> ates-b
> ack-tp4251287p4267311.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users mailing list
http://n2.nabble.com/Trying-to-draw-a-box-on-a-map-and-get-the-coordinates-b
ack-tp4251287p4268014.html
Users mailing list
