[OpenLayers-Users] reprojecting issues
Arnd Wippermann arnd.wippermann at web.de
Tue Jan 12 12:32:44 EST 2010
Your layer are also displayed in lat/lon, but with your extent you are not
able to zoom near enough. Set every time your bounds, then it should work.
if (proj!=='EPSG:4326')
    options.units='m';
    options.maxExtent=new
OpenLayers.Bounds(-2826520,-6354390,4449320,4187770);
else
    options.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);
    options.units='dd';
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Pere Roca Ristol
Gesendet: Dienstag, 12. Januar 2010 14:02
An: users at openlayers.org
Betreff: [OpenLayers-Users] reprojecting issues
hi all,
please correct me if I'm wrong.
As far as I have investigated around, if I want to reproject all the layers,
I have to first destroy the map, recreate it with options.projection=my_proj
and recreate all the layers (when destroying the map, layers persist but
params are deleted) and add them
Even with some errors (EPSG 32661 and 3411 are not correctly reprojected) it
can be see on  http://edit.csic.es/geo/mapviewer/projections_test.html
What it doesn't work at all is trying to switch to lat/long (4326), where I
don't get an error but a blank image. Some idea why it happens?
and why 32661 and 3411 are not correctly displayed?
thanks in advance,
Pere
View this message in context:
http://n2.nabble.com/reprojecting-issues-tp4291395p4291395.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
