[OpenLayers-Users] RE WMSGetFeatureInfo error (Style (undefined) not defined on layer) ...
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Tue Jan 19 14:43:22 EST 2010
In the mapfile, you must define a tolerance and a template for both layer
(Argentina and Uruguay)
TOLERANCE 0
TEMPLATE '../template/query.html'
just add "[oid]" in your query.html for now.
In OL
You are querying every layer with a template. Keep it simple and try first
with one layer
 var _wmsControl = new OpenLayers.Control.WMSGetFeatureInfo({
                   //url : _mapfilex,
                    title: 'Click on the map to get information on
layers',
                    queryVisible: true,
                    infoFormat: 'text/html' ,
        layers:         [YOURLAYERNAME of new OpenLayers.Layer.WMS.....]
give it a try...
stela anders <stelaanders at gmail.com>
19/01/2010 02:16 PM
A
cc
openlayers user list <users at openlayers.org>, users-bounces at openlayers.org
Objet
Re: RE [OpenLayers-Users] WMSGetFeatureInfo error (Style (undefined) not
Hi Steve...
Mapserver version:
MapServer version 5.6.0-beta4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE
SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER
SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
One layer definition (Mapfile)
LAYER
        NAME Argentina
        METADATA
            "wms_title"    "Argentina"   ##required
            "wms_feature_info_mime_type" "text/html"
        END
        GROUP "Test"
        TYPE POLYGON
        STATUS ON
        INCLUDE "Connection.map"  ##MSSQL2008
        DATA "the_geom from viwargentina USING UNIQUE oid USING SRID=0"
        PROJECTION
            "+init=epsg:4326"
        END
        CLASS
            COLOR 255 200 255
            STYLE
                OUTLINECOLOR 190 190 190
                WIDTH 1
            END
        END
    END
I´m using GeoExt to be able to use Sublayers, one layer definition :
                new OpenLayers.Layer.WMS("Country",
                _mapfile, {
                    layers: ['Argentina', 'Uruguay'],
                    format: "image/png",
                    transparent: "true"
                    isBaseLayer: true,
                    buffer: 0,
                    visibility: true
Event to register control:
_wmsControl.events.register("getfeatureinfo",map,showInfo);
Thanks
2010/1/19 <Steve.Toutant at inspq.qc.ca>
Wich mapServer version?
Can you send one layer definition of the mapfile and how you create the Ol
layer for this layer?
Do you register an event for this control, please provide all the code
related to this control.
steve
stela anders <stelaanders at gmail.com>@openlayers.org
Envoyé par : users-bounces at openlayers.org
19/01/2010 01:36 PM
A
cc
Objet
Hiii !!
I´m using Mapserver WMS + Openlayers...
I created a WMSGetFeatureInfo control, when I try to use I got that error:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "
http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd">
<ServiceExceptionReport version="1.1.0">
<ServiceException code="StyleNotDefined">
msWMSLoadGetMapParams(): WMS server error. Style (undefined) not defined
on layer.
</ServiceException>
</ServiceExceptionReport>
My control :
                    url : _mapfilex,
layers',
                    queryVisible: true,
                    infoFormat: 'application/vnd.ogc.wms_xml'
All layers on my mapfile have Style defined...
Any idea?
Thanks
Stella_______________________________________________
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100119/05005fb0/attachment.html
