[OpenLayers-Users] RE WMSGetFeatureInfo error (Style (undefined) not defined on layer) ...
stela anders stelaanders at gmail.com
Tue Jan 19 14:16:12 EST 2010
Hi Steve...
Mapserver version:
MapServer version 5.6.0-beta4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE
SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER
SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
One layer definition (Mapfile)
LAYER
        NAME Argentina
        METADATA
            "wms_title"    "Argentina"   ##required
            "wms_feature_info_mime_type" "text/html"
        END
        GROUP "Test"
        TYPE POLYGON
        STATUS ON
        INCLUDE "Connection.map"  ##MSSQL2008
        DATA "the_geom from viwargentina USING UNIQUE oid USING SRID=0"
        PROJECTION
            "+init=epsg:4326"
        END
        CLASS
            COLOR 255 200 255
            STYLE
                OUTLINECOLOR 190 190 190
                WIDTH 1
            END
        END
    END
I´m using GeoExt to be able to use Sublayers, one layer definition :
                new OpenLayers.Layer.WMS("Country",
                _mapfile, {
                    layers: ['Argentina', 'Uruguay'],
                    format: "image/png",
                    transparent: "true"
                    isBaseLayer: true,
                    buffer: 0,
                    visibility: true
Event to register control:
_wmsControl.events.register("getfeatureinfo",map,showInfo);
Thanks
2010/1/19 <Steve.Toutant at inspq.qc.ca>
> Wich mapServer version?
> Can you send one layer definition of the mapfile and how you create the Ol
> layer for this layer?
> Do you register an event for this control, please provide all the code
> related to this control.
> steve
>  *stela anders <stelaanders at gmail.com>@openlayers.org*
> Envoyé par : users-bounces at openlayers.org
> 19/01/2010 01:36 PM
>   A
> openlayers user list <users at openlayers.org>
> cc
>   Objet
> [OpenLayers-Users] WMSGetFeatureInfo error (Style (undefined) not
> Hiii !!
> I´m using Mapserver WMS + Openlayers...
> I created a WMSGetFeatureInfo control, when I try to use I got that error:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM "*
> http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd*<http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd>
> <ServiceExceptionReport version="1.1.0">
> <ServiceException code="StyleNotDefined">
> msWMSLoadGetMapParams(): WMS server error. Style (undefined) not defined on
> layer.
> </ServiceException>
> </ServiceExceptionReport>
> My control :
>  var _wmsControl = new OpenLayers.Control.WMSGetFeatureInfo({
>                     url : _mapfilex,
>                     title: 'Click on the map to get information on layers',
>                     queryVisible: true,
>                     infoFormat: 'application/vnd.ogc.wms_xml'
> All layers on my mapfile have Style defined...
> Any idea?
> Thanks
> Stella_______________________________________________
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100119/74c365dd/attachment.html
