[OpenLayers-Users] Search for features, show popup when select
Herman Badenhorst hbadenhorst at hotmail.com
Wed Jan 20 07:06:36 EST 2010
Hi group.
What i need to do is display a list of search results in the grid panel.
When user clicks on a record, highlight the feature and display a popup with
the feature attributes.
The code below does all except the popup. How would i go about displaying
the popup?
Regards,
Herman
                      *new* Ext.grid.GridPanel({
                          title: 'Search results',
                          region: 'center',
                          ds: store,
                          sm: sm,
                          autoSizeColumns: *true*,
                          viewConfig: {
                              forceFit: *true*,
                              autoFill: *true*
                          height: 300,
                          columns: [{
                                  header: 'mapunit',
                                  dataIndex: 'mapunit',
                                  width: 50
                          listeners: {
                              'rowclick': {
                                  'fn': *function*(grid, index, evt) {
                                      *var* r =
grid.getStore().getAt(index);
                                      *var* feature = r.get('feature');
                                      *var* a = feature.attributes;
                                      vectorLayer.destroyFeatures();
                                      vectorLayer.addFeatures(feature);
                                      vectorLayer.redraw();
                                      *var* bounds =
feature.geometry.getBounds();
map.setCenter(bounds.getCenterLonLat(),map.getZoomForExtent(bounds));
//                                    popup code goes here?
                           bbar: [{
                               text: 'Clear highlight',
                               handler: *function*() {
vectorLayer.removeFeatures(vectorLayer.features);
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100120/d125f0c9/attachment.html
