[OpenLayers-Users] Search for features, show popup when select
Marc Jansen jansen at terrestris.de
Wed Jan 20 07:20:01 EST 2010
Hi Herman,
I'd try this at the place where you have your comment in the
rowclick-callback-function:
var popup = new OpenLayers.Popup.FramedCloud(
  "chicken",
  bounds.getCenterLonLat(),
  null,
  "<div style='font-size:.8em'>Feature: " + feature.id +"<br />Area: " + feature.geometry.getArea()+"</div>",
  null,
  true
feature.popup = popup;
map.addPopup(popup);
untested, original code from
http://www.openlayers.org/dev/examples/select-feature-openpopup.html
Regards,
Marc
Herman Badenhorst wrote:
> Hi group.
> What i need to do is display a list of search results in the grid
> panel. When user clicks on a record, highlight the feature and display
> a popup with the feature attributes.
> The code below does all except the popup. How would i go about
> displaying the popup?
> Regards,
> Herman
>                       *new* Ext.grid.GridPanel({
>                           title: 'Search results',
>                           region: 'center',
>                           ds: store,
>                           sm: sm,
>                           autoSizeColumns: *true*,
>                           viewConfig: {
>                               forceFit: *true*,
>                               autoFill: *true*
>                           height: 300,
>                           columns: [{
>                                   header: 'mapunit',
>                                   dataIndex: 'mapunit',
>                                   width: 50
>                           listeners: {
>                               'rowclick': {
>                                   'fn': *function*(grid, index, evt) {
>                                       *var* r =
> grid.getStore().getAt(index);
>                                       *var* feature = r.get('feature');
>                                       *var* a = feature.attributes;
>                                       vectorLayer.destroyFeatures();
>                                       vectorLayer.addFeatures(feature);
>                                       vectorLayer.redraw();
>                                       *var* bounds =
> feature.geometry.getBounds();
>                                     map.setCenter(bounds.getCenterLonLat(),map.getZoomForExtent(bounds));
> //                                    popup code goes here?
>                            bbar: [{
>                                text: 'Clear highlight',
>                                handler: *function*() {
> vectorLayer.removeFeatures(vectorLayer.features);
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
  Dipl.-Geogr. Marc Jansen
  - Anwendungsentwickler -
  terrestris GmbH & Co. KG
  Irmintrudisstraße 17
  53111 Bonn
  Tel:    ++49 (0)228 / 96 28 99 -53
  Fax:    ++49 (0)228 / 96 28 99 -57
  Email:  jansen at terrestris.de
  Web:    http://www.terrestris.de
  Amtsgericht Bonn, HRA 6835
  Komplementärin:  terrestris Verwaltungsgesellschaft mbH
  vertreten durch: Hinrich Paulsen, Till Adams
