[OpenLayers-Users] Search for features, show popup when select
Andreas Hocevar ahocevar at opengeo.org
Wed Jan 20 09:04:42 EST 2010
Herman Badenhorst wrote:
> Hi group.
> What i need to do is display a list of search results in the grid
> panel. When user clicks on a record, highlight the feature and display
> a popup with the feature attributes.
> The code below does all except the popup. How would i go about
> displaying the popup?
OpenLayers.Popup or GeoExt.Popup? If the latter, then this is the wrong
list.
If the former, then have a look at
http://www.openlayers.org/dev/examples/sundials.html, which should help
you figure it out.
Regards,
Andreas.
> Regards,
> Herman
>                       *new* Ext.grid.GridPanel({
>                           title: 'Search results',
>                           region: 'center',
>                           ds: store,
>                           sm: sm,
>                           autoSizeColumns: *true*,
>                           viewConfig: {
>                               forceFit: *true*,
>                               autoFill: *true*
>                           height: 300,
>                           columns: [{
>                                   header: 'mapunit',
>                                   dataIndex: 'mapunit',
>                                   width: 50
>                           listeners: {
>                               'rowclick': {
>                                   'fn': *function*(grid, index, evt) {
>                                       *var* r =
> grid.getStore().getAt(index);
>                                       *var* feature = r.get('feature');
>                                       *var* a = feature.attributes;
>                                       vectorLayer.destroyFeatures();
>                                       vectorLayer.addFeatures(feature);
>                                       vectorLayer.redraw();
>                                       *var* bounds =
> feature.geometry.getBounds();
>                                     map.setCenter(bounds.getCenterLonLat(),map.getZoomForExtent(bounds));
> //                                    popup code goes here?
>                            bbar: [{
>                                text: 'Clear highlight',
>                                handler: *function*() {
> vectorLayer.removeFeatures(vectorLayer.features);
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
