[OpenLayers-Users] [MapFish-Users] wrong scale and offset
Sarah Schuessler sarah_flip at yahoo.de
Fri Jan 22 05:28:10 EST 2010
Hi eric and list,
thanks for your answer!
I play around with mapfish example from quickstart, so my code is as the following:
var createMap = function() {
        return new OpenLayers.Map({
              projection: new OpenLayers.Projection("EPSG:31467"),
              displayProjection: new OpenLayers.Projection("EPSG:4326"),
              //minScale: 1000000,
             //maxSclae: 5000,
             scales: [300100,250000, 150000 ,90000, 70000, 60000, 50000, 40000, 30000, 20000, 10000, 5000],
             units: "dd",
             numZoomLevels: 12,
             maxResolution: 0.025, //"auto",
             maxExtent: new OpenLayers.Bounds(7.7,47.57,10.501,49.571),
            allOverlays: false,
            controls: []
I played around with resolution for wms layers (both from ArcIMS with defined minscale and maxscale) which has scale issue:
 new OpenLayers.Layer.WMS("WMS1", "http://myserver/wmsconnector/com.esri.wms.Esrimap/My_GIS?",
        {layers: '0', format: "image/png", transparent: true }, {projection: "EPSG:4326", isBaseLayer: true, displayInLayerSwitcher: true, visibility: true, resolutions: [0.0000952, 0.0001269, 0.0001587 ]} ),
But that did not change anything.
Please ask again if something is not clear or you need more code.
Thanks
best regards
Sarah
Von: Eric Lemoine <eric.lemoine at camptocamp.com>
An: Sarah Schuessler <sarah_flip at yahoo.de>
CC: users at mapfish.org; users at openlayers.org
Gesendet: Donnerstag, den 21. Januar 2010, 22:33:10 Uhr
Betreff: Re: [MapFish-Users] wrong scale and offset
On Wednesday, January 20, 2010, Sarah Schuessler <sarah_flip at yahoo.de> wrote:
> Hi list,
> I wanted to show that I solved one of my problems:
> offsets went away after I added 'projection: EPSG:4236' to my OpenLayers.Layer.WMS.
> I could not manage problem about scale. Any hints about that?
Hi. This is hard (at least to me) to help you with so little
information. Please provide a live example showing the problem, or, if
that's not an option for you, share some of your code with the list.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
__________________________________________________
Do You Yahoo!?
Sie sind Spam leid? Yahoo! Mail verfügt über einen herausragenden Schutz gegen Massenmails.
http://mail.yahoo.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100122/5d85fea4/attachment.html
