[OpenLayers-Users] Style of line which geometry is being changed
Max Weidemann max.weidemann at freenet.de
Thu Jan 28 09:53:11 EST 2010
Hello Poul,
the styleinformation of this virtual points (vertices) is set in the
initialize function of the ModifyFeatureControl.
If you want to change the style i think you have to do it there.
     * Constructor: OpenLayers.Control.ModifyFeature
     * Create a new modify feature control.
     * Parameters:
     * layer - {<OpenLayers.Layer.Vector>} Layer that contains features that
     *     will be modified.
     * options - {Object} Optional object whose properties will be set on
the
     *     control.
    initialize: function(layer, options) {
        this.layer = layer;
        this.vertices = [];
        this.virtualVertices = [];
        this.virtualStyle = OpenLayers.Util.extend({},
            this.layer.style || this.layer.styleMap.createSymbolizer());
        this.virtualStyle.fillOpacity =
0.3;<------------------------------change this to 1
        this.virtualStyle.strokeOpacity =
        this.deleteCodes = [46, 68];
        this.mode = OpenLayers.Control.ModifyFeature.RESHAPE;
        OpenLayers.Control.prototype.initialize.apply(this, [options]);
        if(!(this.deleteCodes instanceof Array)) {
            this.deleteCodes = [this.deleteCodes];
I hope this will help you.
cheers,
Max
View this message in context: http://n2.nabble.com/Style-of-line-which-geometry-is-being-changed-tp4469289p4473704.html
