[OpenLayers-Users] Layer Z order with Google and WMS
Brad Spencer brad at cubewerx.com.au
Tue Mar 2 16:52:37 EST 2010
Dan, as far as I understand you cannot use GoogleMaps as an overlay only a
basemap - someone may correct me there? I assume your WMS layer is
transparent?
Cheers, Brad...
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of ChiefDan
Sent: Wednesday, March 03, 2010 8:08 AM
To: users at openlayers.org
Subject: [OpenLayers-Users] Layer Z order with Google and WMS
I've got a NOAA Chart that is being served up via WMS that I would like to
use with a Google Map base layer. The issue is I want the Chart layer
rendered first, then Google layer so the land will be visible, but the chart
shows in the ocean. The chart is being served up via Tilecache. With a
normal WMS query, you can specify the layer rendering order to achieve the
same effect, however I am unsure if this is possible when mixing in a Google
layer.
I'd appreciate any pointers to if this is possible.
Thanks,
Dan
View this message in context:
http://n2.nabble.com/Layer-Z-order-with-Google-and-WMS-tp4663678p4663678.htm
l
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
