[OpenLayers-Users] Layer Z order with Google and WMS
ChiefDan ChiefDan at gmail.com
Tue Mar 2 16:08:19 EST 2010
I've got a NOAA Chart that is being served up via WMS that I would like to
use with a Google Map base layer. The issue is I want the Chart layer
rendered first, then Google layer so the land will be visible, but the chart
shows in the ocean. The chart is being served up via Tilecache. With a
normal WMS query, you can specify the layer rendering order to achieve the
same effect, however I am unsure if this is possible when mixing in a Google
layer.
I'd appreciate any pointers to if this is possible.
Thanks,
Dan
View this message in context: http://n2.nabble.com/Layer-Z-order-with-Google-and-WMS-tp4663678p4663678.html
