[OpenLayers-Users] How to add more than one container into a treepanel
bartvde at osgis.nl bartvde at osgis.nl
Fri Mar 5 02:52:20 EST 2010
Wrong list.
Please use:
http://www.geoext.org/cgi-bin/mailman/listinfo/users
Best regards,
Bart
> Dear list member,
> I have two GeoExt.tree container. One is BaseLayerContainer and the other
> one is OverlayLayerContainer.
> I aim to merge them in a single Ext.tree.TreePanel so that they are both
> seen but seperately. The following procedure does not work:
> (They are trying to load the layers but they are not loaded)
> *    var layerTree = new Ext.tree.TreePanel({
>         title: "Layers",
>         root: new Ext.tree.AsyncTreeNode({
>             expanded: true,
>             children: [layerTreeBase, layerTreeFeaturesInternal]
>         rootVisible: false,
>         split: true,
>         collapsible: true,
>         collapseMode: "mini",
>         autoScroll: true,
>         lines: false,
>         enableDD: true
> when I modify root as shown below the application works but only with
> baselayers.
> *root: layerTreeBase
> *What should I do in order to display both baselayers and other layers in
> a
> tree format.*
> *Best Regards,
> Ozgur
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
