[OpenLayers-Users] WFS Not loading
Brian Stempin brian.stempin at gmail.com
Sun Mar 7 20:15:41 EST 2010
Hi Lewis,
Sorry for the delay.  Now that I'm on spring break, I can take a little more
time to look at your problem.  Here are a few things I'd suggest:
   1. Your WFS response indicates that you're using WFS 1.0.0.  Try using
   protocol 1.1.0.
   2. You set the projection in the WFS object, which is clearly getting a
   response in that projection.  Try setting the projection of the layer.  One
   of the layer options might be *projection: new
   OpenLayers.Projection("EPSG:26915")*
HTH,
Brian
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100307/ca05d921/attachment.html
