[OpenLayers-Users] WFS Not loading
Lewis Oaten sphyrz at gmail.com
Mon Mar 8 13:44:22 EST 2010
Hi Brian,
Thank you very much for your continued support.
I have altered the version to 1.1.0, this is reflected in the
response. Still, no WFS data is displayed on the map.
I also included an explicit OpenLayers projection, this hasn't worked
either. In searching for the syntax for the projection code, I saw an
example of how to specify style information. I added that code as well
which also failed to produce a change in the output.
Any further thoughts?
Kind regards,
Lewis Oaten
web: lewisoaten.com
twit: twitter.com/lewisoaten
key: pk.caecus.co.uk
cal: tgl.me/LewisOaten
On Mon, Mar 8, 2010 at 1:15 AM, Brian Stempin <brian.stempin at gmail.com> wrote:
> Hi Lewis,
> Sorry for the delay.  Now that I'm on spring break, I can take a little more
> time to look at your problem.  Here are a few things I'd suggest:
> Your WFS response indicates that you're using WFS 1.0.0.  Try using protocol
> 1.1.0.
> You set the projection in the WFS object, which is clearly getting a
> response in that projection.  Try setting the projection of the layer.  One
> of the layer options might be projection: new
> OpenLayers.Projection("EPSG:26915")
> HTH,
> Brian
