[OpenLayers-Users] WMS GetFeatureInfo
Arnd Wippermann arnd.wippermann at web.de
Thu Mar 11 11:49:34 EST 2010
Mostly this line is your problem:
OpenLayers.ProxyHost = "proxy.cgi?url=";
You need to use a proxy-script.
http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#ProxyHost
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von eoinyp
Gesendet: Donnerstag, 11. März 2010 14:41
An: users at openlayers.org
Betreff: [OpenLayers-Users] WMS GetFeatureInfo
Hi all,
I am trying to use GetFeatureInfo to display the properties of an object
when the user clicks on it. Exactly like in the demo given at:
http://openlayers.org/dev/examples/getfeatureinfo-popup.html
So for starters I copied the source code and tried to set the example up
locally.
But, it wont work when I set it up locally. I updated the openlayers.js
source to "<script
src="http://www.openlayers.org/api/OpenLayers.js"></script>"
I changed nothing else.
The map renders fine, but when I click, nothing happens. There is a
javascript error logged:
Message: Access is denied.
Line: 1078
Char: 46
Code: 0
URI: http://www.openlayers.org/api/OpenLayers.js
Im falling before the first hurdle here...  so frustrating!
Any ideas on how to at least get the example working properly so that I can
proceed?!
Thanks,
Eoin
View this message in context:
http://n2.nabble.com/WMS-GetFeatureInfo-tp4715952p4715952.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
