[OpenLayers-Users] WMS GetFeatureInfo
eoinyp eoinyp at yahoo.com
Fri Mar 12 03:19:22 EST 2010
Thank you Bart, I got it sorted.
Just to follow up for anyone else with a similar problem:
You can set the example up locally without using a proxy. E.g put in local
references to the localhost geoserver layers you want to serve up in your
map BUT you must remove the line
OpenLayers.ProxyHost = "proxy.cgi?url=";
Otherwise, you need to setup the proxy, edit the line accordingly and then
you can reference remotely hosted layer instances.
I hope this helps someone else...
Eoin.
View this message in context: http://n2.nabble.com/WMS-GetFeatureInfo-tp4715952p4721007.html
