[OpenLayers-Users] Filtering a WFS Layer
Ivan Grcic igrcic at gmail.com
Fri Mar 12 18:26:46 EST 2010
OpenLayers.Filter.FeatureId should recieve object with fids property, like this:
  new OpenLayers.Filter.FeatureId({
                                fids: [feature.fid]
On Fri, Mar 12, 2010 at 11:23 AM, Andrew Haigh
<haighaj+ollist at googlemail.com> wrote:
> I'm attempting to work out how to apply a filter to a WFS layer (from
> GeoServer 2.0.1), I've looked at the examples / documentation / forums and
> there seems to be a lot of discussion about doing this but I can't seem to
> find a definative solution.
> I've seen this thread
> http://n2.nabble.com/WFS-GetFeature-Filter-td4026139.html which seems to
> indicate I need to download the latest build, so I'm using the nightly build
> from the OpenLayers site which reports a version number of 'Revision 10086'.
> This is my code:
> wfsLayer = new OpenLayers.Layer.Vector( "WFS", {
>    strategies: [new OpenLayers.Strategy.BBOX()],
>    projection: new OpenLayers.Projection("EPSG:27700"),
>    maxExtent: new OpenLayers.Bounds(0, 0, 13000000, 13000000),
>    styleMap: mstylemap,
>    protocol: new OpenLayers.Protocol.WFS({
>        url: "/MyApp/Proxy.ashx",
>        version: "1.1.0",
>        srsName: "EPSG:27700",
>        featurePrefix: "ora_store",
>        featureType: "BOUNDARY",
>        geometryName: "GEOM",
>        featureID: "OBJECTID",
>        defaultFilter: new
> OpenLayers.Filter.FeatureId(["BOUNDARY.1102283472"]) // should this be
> 1102283472 ?
> The FireFox error console reports: Error: uncaught exception: Filter writing
> not supported for rule type: undefined
> If I comment out the filter then the WFS layer works fine.
> So it appears that I've done something wrong in configuring my filter but I
> can't seem to work out what.
> Do I need to set the filter elsewhere?
You can aslo apply filter to filter property on layer, you dont have
to do it on defaultFilter on protocol. If both filters are supplied
they get combined  I think...
> Also when using the FeatureId filter I assume I should use the ID as
> returned in GML (BOUNDARY.1102283472) and not as stored in the database
> (1102283472) - is that correct? I've tested both ways and get the same
> error.
Yesm ID is same as Geoserver supplies it
> Thanks in advance
> Andrew
Cheers,
Ivan
