[OpenLayers-Users] Filtering a WFS Layer
Andrew Haigh haighaj+ollist at googlemail.com
Mon Mar 15 06:11:15 EDT 2010
Ivan,
Thanks for the input I'll investigate that approach
Andrew
On 12 March 2010 23:26, Ivan Grcic <igrcic at gmail.com> wrote:
> Hi,
> OpenLayers.Filter.FeatureId should recieve object with fids property, like
> this:
>  new OpenLayers.Filter.FeatureId({
>                                fids: [feature.fid]
> On Fri, Mar 12, 2010 at 11:23 AM, Andrew Haigh
> <haighaj+ollist at googlemail.com <haighaj%2Bollist at googlemail.com>> wrote:
> > I'm attempting to work out how to apply a filter to a WFS layer (from
> > GeoServer 2.0.1), I've looked at the examples / documentation / forums
> and
> > there seems to be a lot of discussion about doing this but I can't seem
> to
> > find a definative solution.
> > I've seen this thread
> > http://n2.nabble.com/WFS-GetFeature-Filter-td4026139.html which seems to
> > indicate I need to download the latest build, so I'm using the nightly
> build
> > from the OpenLayers site which reports a version number of 'Revision
> 10086'.
> > This is my code:
> > wfsLayer = new OpenLayers.Layer.Vector( "WFS", {
> >    strategies: [new OpenLayers.Strategy.BBOX()],
> >    projection: new OpenLayers.Projection("EPSG:27700"),
> >    maxExtent: new OpenLayers.Bounds(0, 0, 13000000, 13000000),
> >    styleMap: mstylemap,
> >    protocol: new OpenLayers.Protocol.WFS({
> >        url: "/MyApp/Proxy.ashx",
> >        version: "1.1.0",
> >        srsName: "EPSG:27700",
> >        featurePrefix: "ora_store",
> >        featureType: "BOUNDARY",
> >        geometryName: "GEOM",
> >        featureID: "OBJECTID",
> >        defaultFilter: new
> > OpenLayers.Filter.FeatureId(["BOUNDARY.1102283472"]) // should this be
> > 1102283472 ?
> > The FireFox error console reports: Error: uncaught exception: Filter
> writing
> > not supported for rule type: undefined
> > If I comment out the filter then the WFS layer works fine.
> > So it appears that I've done something wrong in configuring my filter but
> I
> > can't seem to work out what.
> > Do I need to set the filter elsewhere?
> You can aslo apply filter to filter property on layer, you dont have
> to do it on defaultFilter on protocol. If both filters are supplied
> they get combined  I think...
> > Also when using the FeatureId filter I assume I should use the ID as
> > returned in GML (BOUNDARY.1102283472) and not as stored in the database
> > (1102283472) - is that correct? I've tested both ways and get the same
> > error.
> Yesm ID is same as Geoserver supplies it
> > Thanks in advance
> > Andrew
> Cheers,
> Ivan
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100315/0d07ddf1/attachment.html
