[OpenLayers-Users] Change the color palette of a raster image
Ivan Grcic igrcic at gmail.com
Fri Mar 12 18:29:46 EST 2010
Hi, you can change pallete on ur wms server, not on client (although
it can maybe be possbile with canvas)
Check: http://geoserver.org/display/GEOSDOC/Paletted+images+tutorial
http://www.google.com/search?q=geoserver+pallete
cheers
On Fri, Mar 12, 2010 at 5:11 PM, Piero Campa <piero.campa at gmail.com> wrote:
> Hello to all of you,
> do you know if that's possible with OpenLayers?
> Or may I specify a transparent color?
> I believe it's not possible, but you may have some hint.
> (Is there maybe an external Javascript library which can do that?)
> Thank you ;-)
> Piero
> View this message in context: http://n2.nabble.com/Change-the-color-palette-of-a-raster-image-tp4722891p4722891.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Ivan Grcic
