[OpenLayers-Users] Control TYPE_TOOL and trigger event
Armin Burger armin.burger at gmx.net
Mon Mar 15 16:13:34 EDT 2010
It is defined as
OpenLayers.Control.RectangleBox = OpenLayers.Class(OpenLayers.Control, {
     type: OpenLayers.Control.TYPE_TOOL,
armin
On 15/03/2010 21:05, Frost89 wrote:
> You should check if the control has an actual type (using your favorite
> debugger). If it is null then it might be necessary to specify the
> controltype in the constructor, like this:
> new OpenLayers.Control.DrawFeature(vectorLayer, OpenLayers.Handler.Polygon,
> In this example my control's type was null by default, so I had to set the
> type myself. This could be the same problem you're having.
