[OpenLayers-Users] Doubt with SOSCapabilities
Maribel Bernal maribel.bernal at iviron.com
Tue Mar 16 08:17:59 EDT 2010
Yes, my SOS structure is a little bit different. You can see my SOS's
GetCapabilites response here: http://pastebin.com/vwr3nx37
An example of my question is at this tag (line #750):
<sos:ObservationOffering gml:id="DISTANCE">
where the offering named "DISTANCE" has 10 procedures, of which only one
really belongs to feature 'foi_k2m_contenedor' (the other nine
procedures are from other features).
When I click over the point 'foi_k2m_contenedor' in the map, I see a
popup in which they appear all 10 procedures. I just want to see the
procedure that belongs to 'foi_k2m_contenedor' feature. It's possible?
Thanks for all.
bartvde at osgis.nl escribió:
> Hi,
> not sure I really get your question, can you elaborate a bit? Is this
> something you can read from the GetCapabilities, or the info needs to be
> retrieved through a request on the SOS? If so, which request, and do you
> have an example XML request?
> If I understand things correctly, in the example SOS used one feature of
> interest has exactly one procedure, and they have the same id.
> Is your SOS structure different, and if so, can you post your SOS's
> GetCapabilities response using something like pastebin? TIA.
> Best regards,
> Bart
>> Hi all,
>> Following the example (http://openlayers.org/dev/examples/sos.html), I'm
>> using OpenLayers.js to connect by my local SOS which is based to 52North
>> model, and it works correctly.
>> I have seen the result of the GetCapabilities request is an array of
>> "offerings", and within each offering there are two separate arrays: the
>> "features of interest" and the "procedures" related with this offering.
>> In the map, I can see the points that represents the "features of
>> interest". When I click over a point, due to each feature can have one
>> or more "offerings" associated, in the popup I see all the procedures
>> related by all offerings of this FoI.
>> My question is:
>> There are any way to directly obtain only the "procedures" of a "feature
>> of interest" regardless the offerings?
>> Thank you very much.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
