[OpenLayers-Users] Doubt with SOSCapabilities
bartvde at osgis.nl bartvde at osgis.nl
Tue Mar 16 07:39:58 EDT 2010
not sure I really get your question, can you elaborate a bit? Is this
something you can read from the GetCapabilities, or the info needs to be
retrieved through a request on the SOS? If so, which request, and do you
have an example XML request?
If I understand things correctly, in the example SOS used one feature of
interest has exactly one procedure, and they have the same id.
Is your SOS structure different, and if so, can you post your SOS's
GetCapabilities response using something like pastebin? TIA.
Best regards,
Bart
> Hi all,
> Following the example (http://openlayers.org/dev/examples/sos.html), I'm
> using OpenLayers.js to connect by my local SOS which is based to 52North
> model, and it works correctly.
> I have seen the result of the GetCapabilities request is an array of
> "offerings", and within each offering there are two separate arrays: the
> "features of interest" and the "procedures" related with this offering.
> In the map, I can see the points that represents the "features of
> interest". When I click over a point, due to each feature can have one
> or more "offerings" associated, in the popup I see all the procedures
> related by all offerings of this FoI.
> My question is:
> There are any way to directly obtain only the "procedures" of a "feature
> of interest" regardless the offerings?
> Thank you very much.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
