[OpenLayers-Users] Building Openlayers on Windows - build.py
Shawn Oatley shawn at niagarafalls.ca
Tue Mar 16 08:55:37 EDT 2010
I had the same problem with the build.py file and was executing it from a batch file.  You need to go to the directory and then execute the build.py file I.E.:
D:
cd \gwt\openlayers-2.8\openlayers-2.8\build
build.py full.cfg
Try that and you should be good to go...
Shawn
>>> On 3/16/2010 at 7:47 AM, paweluz <paweluz at o2.pl> wrote:
Hi!
I have done some changes to the fiole XMLHttpRequest.js file, and now I want
to build Openlayers (deploy to one OpenLayers.js file) but I having some
problem... I am using OpenLayers 2.8 on Windows2000 and Python2.6. I opened
the cmd and tried this approaches:
- D:\GWT\OpenLayers-2.8\OpenLayers-2.8\build\build.py
I got ImportError: No module named mergejs
This is weird because in the begging of the build.py file I have line
'sys.path.append("../tools") ', so I think the file should be available.
- I copied the file mergejs from tool folder to build folder and try one
again D:\GWT\OpenLayers-2.8\OpenLayers-2.8\build\build.py
I got IOError: [Errno 2] No such file or directory: 'full.cfg'
This is also weird because it is in the same folder
- I tried D:\GWT\OpenLayers-2.8\OpenLayers-2.8\build\build.py full.cfg
D:\GWT\OpenLayers-2.8\OpenLayers-2.8\build\full.cfg
I got ImportError: No module named toposort
- I copy the file from tool folder to build folder and try again
I got KeyError: 'OpenLayers/SingleFile.js'
What is going on... all I got are errors. Am I doing something wrong. My
python is working fine for sure. So I do not know what is wrong...
Any help, please...
Poul
View this message in context: http://n2.nabble.com/Building-Openlayers-on-Windows-build-py-tp4743084p4743084.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100316/289b8765/attachment.html
