[OpenLayers-Users] SaveStrategy does not work - WFSProtocol with Vector Layer
moataz Elmasry zaza1851983ml at googlemail.com
Fri Mar 19 09:54:29 EDT 2010
I might be wrong concerning the proxy issue. But to clear something
here, you would still see the vector layer and the features you add per
hand to that layer, unrelated to, whether these features are added to
the db or not.
My concern here is that how can we make sure that the transaction has
been performed successfully (or not), since what you do on the vector
layer is browser-local and independant from the data in the db
paweluz wrote:
> Hi!
> I am familiar with the proxy issue, but in my case it should not be the
> problem. If it was I wouldn't see the vector layer at all (I suppose). I
> have both geoserver and my application running on this same server
> application - Glassfish, in this case the proxy should not be the issue...
> don't you think ? or maybe I am wrong...
> Poul
