[OpenLayers-Users] SaveStrategy does not work - WFSProtocol with Vector Layer
paweluz paweluz at o2.pl
Fri Mar 19 10:54:01 EDT 2010
Hi!
Thanks a lot for your interest. I have changed the configuration just to
check if it was depending on the proxy issue. Now I have Tomcat running my
application and geoserver running from the exe file (on windows 2000). I am
using OpenLayers proxy file. Now I got in firebug an error... The Source is
this same but the response:
Response
<ows:ExceptionReport version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/ows
http://localhost:1234/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ows="http://www.opengis.net/ows">
  <ows:Exception exceptionCode="InvalidParameterValue">
    <ows:ExceptionText>Error performing insert</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
I have checked the logs file. There is nothing wrong in the Postgresql log
file, but there is something in the geoserver file... I put the most part of
the log file.
Log file from the geoserver
19 mar 15:36:30 INFO [geoserver.wfs] -
Request: getServiceInfo
19 mar 15:36:30 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: Error performing insert
	at
org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:200)
	at org.geoserver.wfs.Transaction.execute(Transaction.java:333)
	at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
	at
org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:182)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
	at java.lang.reflect.Method.invoke(Method.java:597)
	at
org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
	at
org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
	at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
	at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
	at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
	at
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
	at $Proxy16.transaction(Unknown Source)
	at
	at
	at
org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:583)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:212)
	at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
	at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
	at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
	at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
	at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
	at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
	at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
	at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
	at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
	at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
	at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
	at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
	at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
	at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
	at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
	at
	at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
	at
	at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
	at
	at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
	at
	at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
	at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
	at
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
	at
	at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
	at
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
	at
	at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
	at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
	at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
	at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
	at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
	at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
	at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
	at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
	at org.mortbay.jetty.Server.handle(Server.java:324)
	at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
	at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
	at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
	at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
	at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
	at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
	at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.ClassCastException: java.lang.String cannot be cast to
com.vividsolutions.jts.geom.Geometry
	at
org.geotools.data.jdbc.JDBCTextFeatureWriter.makeInsertSql(JDBCTextFeatureWriter.java:225)
	at
org.geotools.data.jdbc.JDBCTextFeatureWriter.doInsert(JDBCTextFeatureWriter.java:116)
	at
org.geotools.data.jdbc.JDBCFeatureWriter.write(JDBCFeatureWriter.java:215)
	at
org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:335)
	at
org.geotools.data.jdbc.JDBCFeatureStore.addFeatures(JDBCFeatureStore.java:383)
	at
org.vfny.geoserver.global.GeoServerFeatureStore.addFeatures(GeoServerFeatureStore.java:81)
	at
org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:169)
	... 70 more
Request: transaction
	handle = null
	service = WFS
	version = 1.1.0
	baseUrl = http://localhost:1234/geoserver/
	providedVersion = 1.1.0
	lockId = null
	group = [wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl at 2f71d9
(feature: [org.geotools.feature.simple.SimpleFeatureImpl at df6f63a9], handle:
null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
	insert = [net.opengis.wfs.impl.InsertElementTypeImpl at 2f71d9 (feature:
[org.geotools.feature.simple.SimpleFeatureImpl at df6f63a9], handle: null,
	update = []
	delete = []
	native = []
	releaseAction = ALL
19 mar 15:36:30 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Error performing insert
	at
org.geoserver.wfs.response.v1_1_0.TransactionResponse.write(TransactionResponse.java:49)
	at org.geoserver.ows.Dispatcher.response(Dispatcher.java:712)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
	at
What do you think about this ? I have no idea what to do... Before I was
using WFS layer but now it is deprecated so I used Vector layer with save
strategy. I have no idea what is wrong. Tomorrow I am going to check
everything on different PC and system... Maybe this is the issue...
Any ideas??
Poul
View this message in context: http://n2.nabble.com/SaveStrategy-does-not-work-WFSProtocol-with-Vector-Layer-tp4762666p4763416.html
