[OpenLayers-Users] SaveStrategy does not work - WFSProtocol with Vector Layer
Maxime Phaneuf maxime.phaneuf at usherbrooke.ca
Fri Mar 19 11:43:16 EDT 2010
Hi
You should try to update your GeoServer version to the most recent one. I
once had this problem and I resolved it like that. Also, be sure NOT to use
the same saveStrategy for different geometry type (i.e. point - line -
polygon).
Maxime
View this message in context: http://n2.nabble.com/SaveStrategy-does-not-work-WFSProtocol-with-Vector-Layer-tp4762666p4763767.html
