[OpenLayers-Users] WFS layer - commit works, save strategy from WFSProtocol does not work!!!! POST vs GET ?!?!
Ramón Boza rboza at sitep.com
Mon Mar 22 06:27:33 EDT 2010
Hello,
Can you use FireBug and post the Request generated to the server ?
-----Mensaje original-----
De: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] En
nombre de paweluz
Enviado el: lunes, 22 de marzo de 2010 11:19
Para: users at openlayers.org
Asunto: [OpenLayers-Users] WFS layer - commit works, save strategy from
Hi!
I have a really strange problem. At the beginning I was thinking that it was
Geoserver fault, or maybe Postgis but now I think this is Openlayers fault.
At first I was using WFS layer, I had implemented insert, update, delete and
modify functions and everything was was working just great. But since WFS
layer is deprecated, I started using vector layer with WFSProtocol. And it
does not work!!!
With WFS layer I use something like this
feature.state = OpenLayers.State.INSERT;
mylayes.commit();
In this case my data was successfully in the database.
In Vector layer I used WFSProtocol. Now when I do :
saveStrategy.save();
But I got response in the firebug.
<ows:ExceptionReport version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/ows
http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ows="http://www.opengis.net/ows">
  <ows:Exception exceptionCode="InvalidParameterValue">
    <ows:ExceptionText>Error performing insert</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Can anyone please explain to me this. How come WFS.commit() works but
savestrategy does not? I know for sure that my code in openlayers is wright.
You may see it in my previous topic:
http://n2.nabble.com/SaveStrategy-does-not-work-WFSProtocol-with-Vector-Laye
r-PROBLEM-WITH-POSTGIS-td4762666.html#a4762666
Maybe the reason is that WFS layer use just GET method, and Vector Layer
(WFSProtocol) uses POST method... Can anyone please help me??
Regards,
Poul
View this message in context:
http://n2.nabble.com/WFS-layer-commit-works-save-strategy-from-WFSProtocol-d
oes-not-work-POST-vs-GET-tp4776941p4776941.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
Se certificó que el correo entrante no contiene virus.
Comprobada por AVG - www.avg.es
Versión: 9.0.791 / Base de datos de virus: 271.1.1/2755 - Fecha de la
versión: 03/21/10 20:33:00
