[OpenLayers-Users] WFS layer - commit works, save strategy from WFSProtocol does not work!!!! POST vs GET ?!?!
Christoph Ratke christoph.ratke at gmx.net
Mon Mar 22 06:47:02 EDT 2010
Hi paweluz,
you could also have a look at the geoserver log and therefor raise the
debug level if needed.
This could give you some more hints what is going wrong.
regards,
Christoph
Ramón Boza schrieb:
> Hello,
> Can you use FireBug and post the Request generated to the server ?
> -----Mensaje original-----
> De: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] En
> nombre de paweluz
> Enviado el: lunes, 22 de marzo de 2010 11:19
> Para: users at openlayers.org
> Asunto: [OpenLayers-Users] WFS layer - commit works, save strategy from
> Hi!
> I have a really strange problem. At the beginning I was thinking that it was
> Geoserver fault, or maybe Postgis but now I think this is Openlayers fault.
> At first I was using WFS layer, I had implemented insert, update, delete and
> modify functions and everything was was working just great. But since WFS
> layer is deprecated, I started using vector layer with WFSProtocol. And it
> does not work!!!
> With WFS layer I use something like this
> feature.state = OpenLayers.State.INSERT;
> mylayes.commit();
> In this case my data was successfully in the database.
> In Vector layer I used WFSProtocol. Now when I do :
> saveStrategy.save();
> But I got response in the firebug.
> <?xml version="1.0" encoding="UTF-8"?>
> <ows:ExceptionReport version="1.0.0"
>   xsi:schemaLocation="http://www.opengis.net/ows
> http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
>   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ows="http://www.opengis.net/ows">
>   <ows:Exception exceptionCode="InvalidParameterValue">
>     <ows:ExceptionText>Error performing insert</ows:ExceptionText>
>   </ows:Exception>
> </ows:ExceptionReport>
> Can anyone please explain to me this. How come WFS.commit() works but
> savestrategy does not? I know for sure that my code in openlayers is wright.
> You may see it in my previous topic:
> http://n2.nabble.com/SaveStrategy-does-not-work-WFSProtocol-with-Vector-Laye
> r-PROBLEM-WITH-POSTGIS-td4762666.html#a4762666
> Maybe the reason is that WFS layer use just GET method, and Vector Layer
> (WFSProtocol) uses POST method... Can anyone please help me??
> Regards,
> Poul
