[OpenLayers-Users] OpenLayers.Control.ModifyFeature
Stephen Woodbridge woodbri at swoodbridge.com
Mon Mar 22 13:01:39 EDT 2010
mario1982 at libero.it wrote:
> How can I deactivate the modify feature control when the select feature control is activated ?
> Is there a way to force the modify feature control disactivation when the other control is active ?
> Both controls operate on the same layer.
You can add them both to a Control.Panel along with a Control.Navigation
widget and then it will act similar to the Control.Toolbar panel.
-Steve W
> Regards,
> Mario
>> On Friday, March 19, 2010, mario1982 at libero.it <mario1982 at libero.it> wrote:
>>> Hi,
>>> I've got a problem with modify feature control.
>>> It seems like onModificationStart event is call always before the other event I've got on my application even if I recall the other event. Is there a way to deactivate this control ?
>>> Here is a my code:
>>> modifyControls = {
>>> modify: new OpenLayers.Control.ModifyFeature(geometrylayer, {title:'Modifica area/percorso',
>>>                 displayClass: 'modify', onModificationStart:onModStart, onModificationEnd:onModEnd, onModification:onMod})
>>> popupControl = new OpenLayers.Control.SelectFeature(geometrylayer,
>>>             {title:'Informazioni sul contenuto' , onSelect: onContentSelectArea, onUnselect: onContentUnselect} );
>>> When I call popupControl, it always call onModificationStart event. I don't know why.
>> Hi
>> what if you deactivate the modify feature control when the select
>> feature control is activated?
>> also, what version of OpenLayers are you using?
>> Cheers,
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
