[OpenLayers-Users] OpenLayers.Control.ModifyFeature
mario1982 at libero.it mario1982 at libero.it
Mon Mar 22 12:28:12 EDT 2010
I've already added them both to a Control.Panel this way:
panel.addControls([popupControl,
	         drawControls.path,
	         drawControls.polygon,
	         drawControls.modify ]);
is it correct ?
Have you got an example ?
Thank you,
Mario
> mario1982 at libero.it wrote:
> > How can I deactivate the modify feature control when the select feature control is activated ?
> > Is there a way to force the modify feature control disactivation when the other control is active ?
> > Both controls operate on the same layer.
> You can add them both to a Control.Panel along with a Control.Navigation
> widget and then it will act similar to the Control.Toolbar panel.
> -Steve W
> > Regards,
> > Mario
> >> On Friday, March 19, 2010, mario1982 at libero.it <mario1982 at libero.it> wrote:
> >>> Hi,
> >>> I've got a problem with modify feature control.
> >>> It seems like onModificationStart event is call always before the other event I've got on my application even if I recall the other event. Is there a way to deactivate this control ?
> >>> Here is a my code:
> >>> modifyControls = {
> >>> modify: new OpenLayers.Control.ModifyFeature(geometrylayer, {title:'Modifica area/percorso',
> >>>                 displayClass: 'modify', onModificationStart:onModStart, onModificationEnd:onModEnd, onModification:onMod})
> >>> popupControl = new OpenLayers.Control.SelectFeature(geometrylayer,
> >>>             {title:'Informazioni sul contenuto' , onSelect: onContentSelectArea, onUnselect: onContentUnselect} );
> >>> When I call popupControl, it always call onModificationStart event. I don't know why.
> >> Hi
> >> what if you deactivate the modify feature control when the select
> >> feature control is activated?
> >> also, what version of OpenLayers are you using?
> >> Cheers,
> >> Eric Lemoine
> >> Camptocamp France SAS
> >> Savoie Technolac, BP 352
> >> 73377 Le Bourget du Lac, Cedex
> >> Tel : 00 33 4 79 44 44 96
> >> Mail : eric.lemoine at camptocamp.com
> >> http://www.camptocamp.com
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
