[OpenLayers-Users] Draw a point and assign a dynamic label to it
Sveen Atle Frenvik (Geomatikk IKT) Atle.Frenvik.Sveen at geomatikk.no
Wed Mar 24 09:16:59 EDT 2010
On 03/24/2010 01:52 PM, Frost89 wrote:
> Hi list
> In my map I have added a vector layer and a drawFeature control.
> The drawFeature is set to draw points, and works without problems.
> Now, I would like to assign a text-label to the point's style.
> The text in the label should be defined by the user (through a prompt() or
> other alternatives).
Try and set the text in the feature's properties:
feature.properties.text = mytext;
and then add a style to the layer you place the feature in:
  var style = new OpenLayers.Style({
  label: "${text}",
(a bit confused about your code snippet, is the event in featureAdded
indeed the created feature?)
-atle
> So I was thinking about settings this value in the "featureAdded" event of
> the drawFeature control, but I can't quite figure out how to do this.
> When I try to do it like this...
> var point = new OpenLayers.Control.DrawFeature(
>    vectorLayer,
>    OpenLayers.Handler.Point,
>      type: OpenLayers.Control.TYPE_TOOL,
>      featureAdded: function(event) {
>        event.style.label = 'test';
>        redliningLayer.drawFeature(event);
> ... I just get an error message:
> event.style is null
> So if anyone has an idea of how to do this, it would be appreciated :)
> - Kristian Frost
Atle Frenvik Sveen
GIS Konsulent
Geomatikk IKT AS
tlf: 45 27 86 89
atle.frenvik.sveen at geomatikk.no
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100324/1163f038/attachment.html
