[OpenLayers-Users] 'xy' property in OpenLayers.Format.GML class
Tim Schaub tschaub at opengeo.org
Wed Mar 24 16:39:40 EDT 2010
Maribel Bernal wrote:
> Hi again,
> I'm using SOSClient class to show any points in a map. Now, the points
> appear as lat-long while in the response of GetCapabilities request of
> my SOS appear as long-lat.
> Someone knows in which function I can set the first number of
> "gml:lowerCorner"/"gml:upperCorner" as longitude and the second as latitude?
> I see that exists a property called "xy" (true by default) in
> OpenLayers.Format.GML class, but is not recommended to change it to
> false. Anyway, I tried to change it but not works...
> Any idea or suggestions?
The default is xy (or longitude, latitude) order.
I'd suggest using the OpenLayers.Format.GML.v3 parser for your version 3
GML.
It looks to me like the older parser (OpenLayers.Format.GML) should
properly apply the xy property when reading envelope coordinates as well.
Can you provide a simple test case that fails?
Tim
> That is the part of my response of the SosCapabilities request, where
> appear a point:
>  <sos:Contents>
>     <sos:ObservationOfferingList>
>       <sos:ObservationOffering gml:id="GAUGE_HEIGHT">
>         <gml:name>The water level in a river</gml:name>
>         <gml:boundedBy>
>           <gml:Envelope srsName="urn:ogc:def:crs:EPSG:4326">
>             <gml:lowerCorner>2.11353 41.1111</gml:lowerCorner>
>             <gml:upperCorner>9.1111 52.9</gml:upperCorner>
>           </gml:Envelope>
>         </gml:boundedBy>
> Thanks at all.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
