[OpenLayers-Users] Vector layer: overlapping data
Tim Schaub tschaub at opengeo.org
Thu Mar 25 13:14:50 EDT 2010
Tim Schaub wrote:
> Daniel Degasperi wrote:
>> Hi,
>> I have a Vector Layer with Linestrings, which can also overlapp and I've
>> applied a SelectFeature Control (with hover effect) to this Vector Layer.
>> My question is, is it possible to bring the current selected feature on
>> top of all features?
I updated [1] the StyleMap example [2] to demonstrate how to use
z-indexing with different render intents.
In addition to using a graphicZIndex (will eventually be zIndex)
property in your symbolizers, you need to enable z-indexing on the
renderer.  To do this, set rendererOptions on your layer as shown in the
example.
To see z-indexing with selection in action, refresh the example until
you see overlapping points.  When you hover over a point, the render
intent changes to "select" and you should see the selected feature drawn
over others.
Tim
[1] http://trac.openlayers.org/changeset/10144
[2] http://openlayers.org/dev/examples/stylemap.html
> See http://trac.openlayers.org/ticket/1066 for the change that made this
> the expected behavior (not to bring selected features to the top).
> We could provide an option to change this behavior.
> Alternatively, you should be able to give your vector layer a style map
> with different styles for the "default" and "select" rendering intents.
>   Using a graphicZIndex property in your symbolizers, you could have
> selected features rendered above unselected features.
> The graphicZIndex property is poorly named.  It looks to me like it
> should apply to any symbolizer - not just a symbolizer that uses an
> external graphic.  I'll confirm this and open a ticket about adding
> support for a more appropriately named "zIndex" property on symbolizers.
> Relevant examples:
> Using graphicZIndex
> http://openlayers.org/dev/examples/marker-shadow.html
> Using a StyleMap with multiple render intents
> Tim
>> Best regards,
>> Daniel
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
