[OpenLayers-Users] Proxy problem in GetFeatureInfo - nosolution??
David Fawcett david.fawcett at gmail.com
Sun Mar 28 14:38:01 EDT 2010
Download the file, rename it with a .txt suffix and open it up with a
text editor.
It is not actually asking you to download the MapServer executable,
you are getting an error message from your WMS server.  The contents
of this file should contain the error message.
David.
On Sun, Mar 28, 2010 at 11:44 AM, sunny74 <sb.ray at hotmail.com> wrote:
> Hi,
> I am tryng to issue a command directly in IE for GFI like below:
> http://localhost:9000/cgi-bin/mapserv.exe?map=../htdocs/shape/newwr1rec.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&STYLES=&EXCEPTIONS=application/vnd.ogc.se.xml&SRS=EPSG:4326&INFO_FORMAT=text/html&Width=600&height=600
> &BBOX=70.4375 17.5375 76.0625
> 23.1625&X=420&Y=297&QUERY_LAYERS=STATE&FEATURE_COUNT=1
> But it is giving dialog box to download mapserv.exe.
> What Am I doing wrong?
> Can someone provide me with the correct url.
> My Mapfile is as given below:
> # Map file created from QGIS project file D:/QGIS/newwr.qgs
> # Edit this file to customize for your map interface
> # (Created with PyQgis MapServer Export plugin)
> MAP
>  NAME newwr.map
>  # Map image size
>  SIZE 600 600
>  UNITS dd
>  EXTENT 67.440106 17.379867 78.390250 25.122977
>  FONTSET "fonts.txt"
>  PROJECTION
>    'proj=longlat'
>    'ellps=WGS84'
>    'datum=WGS84'
>    'no_defs'
>  END
>  # Background color for the map canvas -- change as desired
>  IMAGECOLOR 192 192 192
>  IMAGEQUALITY 95
>  IMAGETYPE gif
>  OUTPUTFORMAT
>    NAME GIF
>    DRIVER 'GD/gif'
>    MIMETYPE 'image/gif'
>    #IMAGEMODE PC256
>    EXTENSION 'gif'
>  END
>  # Legend
>  LEGEND
>      IMAGECOLOR 255 255 255
>    STATUS ON
>    KEYSIZE 18 12
>    LABEL
>      TYPE BITMAP
>      SIZE MEDIUM
>      COLOR 0 0 89
>    END
>  END
>  # Web interface definition. Only the template parameter
>  # is required to display a map. See MapServer documentation
>  WEB
>    # Set IMAGEPATH to the path where MapServer should
>    # write its output.
>    IMAGEPATH '/tmp/'
>    # Set IMAGEURL to the url that points to IMAGEPATH
>    # as defined in your web server configuration
>    IMAGEURL '/tmp/'
>    # WMS server settings
>    METADATA
>      'wms_title'           'newwr.map'
>      'wms_feature_mime_type' 'text/plain'
>      'wms_onlineresource'
> 'http://localhost:9000/cgi-bin/mapserv?map=c:\ms4w\apache\htdocs\Shape\newwr1.map&'
>      'wms_srs'             'EPSG:4326'
>      'queryable'          'true'
>      'wms_proxy_auth_type'    'ntlm'
>      'wms_proxy_host'        'localhost'
>      'wms_proxy_port'        '9000'
>      'wms_proxy_type'        'http'
>      'wms_proxy_username'    'subhro'
>      'wms_proxy_password'    'subh26'
>      'gml_include_items'    'all'
>    END
>    #Scale range at which web interface will operate
>    # Template and header/footer settings
>    HEADER   ../templates/Demo_header.html
>    TEMPLATE ../templates/Demo_query_body.html
>    FOOTER ../templates/Demo_footer.html
>    # Only the template parameter is required to display a map. See
>  END
>  LAYER
>    NAME 'STATE'
>    TYPE POLYGON
>    DATA 'C:\ms4w\Apache\htdocs\Shape\STATE.shp'
>    METADATA
>      'wms_title' 'STATE'
>    END
>    STATUS DEFAULT
>    DUMP TRUE
>    TRANSPARENCY 100
>    PROJECTION
>    'proj=longlat'
>    'ellps=WGS84'
>    'datum=WGS84'
>    'no_defs'
>    END
>    CLASS
>       NAME 'STATE'
>       STYLE
>         SYMBOL 0
>         SIZE 2
>         OUTLINECOLOR 0 0 0
>         COLOR 255 255 127
>       END
>    END
>  END
>  LAYER
>    NAME 'RailwayStations'
>    TYPE POINT
>    DATA 'C:\ms4w\Apache\htdocs\Shape\RailwayStations.shp'
>    LABELITEM 'S_NAME'
>    METADATA
>      'wms_title' 'RailwayStations'
>    END
>    STATUS OFF
>    DUMP TRUE
>    TRANSPARENCY 100
>    PROJECTION
>    'proj=longlat'
>    'ellps=WGS84'
>    'datum=WGS84'
>    'no_defs'
>    END
>    CLASS
>       STYLE
>         SYMBOL 'CIRCLE'
>         SIZE 8
>         OUTLINECOLOR 0 0 0
>         COLOR 255 0 0
>       END
>       LABEL
>                 COLOR 132 31 31
>                 SHADOWCOLOR 218 218 218
>                 SHADOWSIZE 2 2
>                 TYPE TRUETYPE
>                 FONT comic_sans-bold
>                 SIZE 6
>                 ANTIALIAS TRUE
>                 POSITION AUTO
>                 FORCE TRUE
>                 PARTIALS FALSE
>                MINDISTANCE 300
>                BUFFER 4
>            END # end of label
>    END
>  END
>  #Circle symbol
>      SYMBOL
>        NAME 'CIRCLE'
>        TYPE ellipse
>        FILLED true
>        POINTS
>          1 1
>        END
>      END
> END
> And my JS function to call GetFeatureInfo is:
> function init2() {
>            //OpenLayers.ProxyHost =
> "http://127.0.0.1:9000/cgi-bin/proxy.cgi?url=";
>            map = new OpenLayers.Map('<%=map.ClientID%>');
>            layer = new OpenLayers.Layer.WMS("OpenLayers WMS",
>                "http://localhost:9000/cgi-bin/mapserv.exe?", { map:
> '../htdocs/Shape/newwr1rec.map', layers: 'STATE', format: 'png' });
>            layer1 = new OpenLayers.Layer.WMS("Rstations",
> '../htdocs/Shape/newwr1rec.map', transparent: true,layers:
> 'RailwayStations', format: 'png' });
>            map.addLayers([layer,layer1]);
>            //layer = new OpenLayers.Layer.WFS("OpenLayers WFS",
> "http://127.0.0.1:9000/cgi-bin/mapserv.exe?map=d:/ms4w/apache/htdocs/Shape/newwr1.map",
> { typename: 'STATE', maxfeatures: 6 }, { featureClass:
> OpenLayers.Feature.WFS });
>            ///map.addLayer(layer);
>            map.zoomToMaxExtent();
>            map.setCenter(new OpenLayers.LonLat(73.25, 20.35), 6);
>            map.addControl(new OpenLayers.Control.LayerSwitcher());
>            map.events.register('click', map, function(e) {
>                //alert('clicked');
>                OpenLayers.Util.getElement('nodeList').innerHTML =
> "Loading... please wait...";
>                var url = layer.getFullRequestString({
>                    REQUEST: "GetFeatureInfo",
>                    EXCEPTIONS: "application/vnd.ogc.se_xml",
>                    BBOX: map.getExtent().toBBOX(),
>                    X: e.xy.x,
>                    Y: e.xy.y,
>                    INFO_FORMAT: 'text/plain',
>                    QUERY_LAYERS: "RailwayStations",
>                    FEATURE_COUNT: 1,
>                    WIDTH: map.size.w,
>                    HEIGHT: map.size.h
>                //  var msg = document.getElementById('urlmsg');
>                //  msg.value = url;
>                alert(url, "getfeatureinfo",
> "location=0,status=0,scrollbars=1,width=800,height=400");
>                //window.open(url, '', this, setHTML, setHTML);
>                OpenLayers.loadUrl(url, '', this, setHTML);
>                OpenLayers.Event.stop(e);
> I am at square 1 despite all the changes I have done in map file and code.
> window.open is giving the same output as stated earlier and
> does not give any o/p.
> Can someone help me get OpenLayers.loadUrl(url, '', this, setHTML);
> working, any two formats.
> I have been trying for 1 week now but without success.
> PLs provide with a working solution.
> View this message in context: http://n2.nabble.com/Proxy-problem-in-GetFeatureInfo-no-solution-tp4802810p4813726.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
