[OpenLayers-Users] Proxy problem in GetFeatureInfo - nosolution??
sunny74 sb.ray at hotmail.com
Tue Mar 30 01:57:49 EDT 2010
Hi Barend,
I got my mapfile corrected and my map is displaying fine.
My mapfile is like this:
# Map file created from QGIS project file D:/QGIS/newwr.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
  NAME newwr.map
  # Map image size
  SIZE 600 600
  UNITS dd
  EXTENT 67.440106 17.379867 78.390250 25.122977
  FONTSET "fonts.txt"
  PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
  END
  # Background color for the map canvas -- change as desired
  IMAGECOLOR 192 192 192
  IMAGEQUALITY 95
  IMAGETYPE gif
  OUTPUTFORMAT
    NAME GIF
    DRIVER 'GD/gif'
    MIMETYPE 'image/gif'
    #IMAGEMODE PC256
    EXTENSION 'gif'
  END
  # Legend
  LEGEND
      IMAGECOLOR 255 255 255
    STATUS ON
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  # Web interface definition. Only the template parameter
  # is required to display a map. See MapServer documentation
  WEB
    # Set IMAGEPATH to the path where MapServer should
    # write its output.
    IMAGEPATH '/tmp/'
    # Set IMAGEURL to the url that points to IMAGEPATH
    # as defined in your web server configuration
    IMAGEURL '/tmp/'
    # WMS server settings
    METADATA
      'wms_title'           'newwr.map'
      'wms_feature_mime_type' 'text/html'
      'wms_onlineresource'
'http://172.16.0.144:9000/cgi-bin/mapserv?map=d:\ms4w\apache\htdocs\Shape\newwr1rec.map&'
      'wms_srs'             'EPSG:4326'
      'queryable'          'true'
      'wms_proxy_auth_type'    'ntlm'
      'wms_proxy_host'        '172.16.0.144'
      'wms_proxy_port'        '9000'
      'wms_proxy_type'        'http'
      'wms_proxy_username'    'subhranilr'
      'wms_proxy_password'    'subh123$'
      'gml_include_items'    'all'
    END
    #Scale range at which web interface will operate
    # Template and header/footer settings
    HEADER   ../templates/Demo_header.html
    TEMPLATE ../templates/Demo_query_body.html
    FOOTER ../templates/Demo_footer.html
    # Only the template parameter is required to display a map. See
  END
  LAYER
    NAME 'STATE'
    TYPE POLYGON
    DATA 'D:\ms4w\Apache\htdocs\Shape\STATE.shp'
    METADATA
      'wms_title' 'STATE'
    END
    STATUS DEFAULT
    DUMP TRUE
    TRANSPARENCY 100
    PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
    END
    CLASS
       NAME 'STATE'
       STYLE
         SYMBOL 0
         SIZE 2
         OUTLINECOLOR 0 0 0
         COLOR 255 255 127
       END
    END
  END
  LAYER
    NAME 'RailwayStations'
    TYPE POINT
    DATA 'D:\ms4w\Apache\htdocs\Shape\RailwayStations.shp'
    LABELITEM 'S_NAME'
    METADATA
      'wms_title' 'RailwayStations'
    END
    STATUS ON
    DUMP TRUE
    TRANSPARENCY 100
    PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
    END
    CLASS
       STYLE
         SYMBOL 'CIRCLE'
         SIZE 8
         OUTLINECOLOR 0 0 0
         COLOR 255 0 0
       END
       LABEL
                 COLOR 132 31 31
                 SHADOWCOLOR 218 218 218
                 SHADOWSIZE 2 2
                 TYPE TRUETYPE
                 FONT comic_sans-bold
                 SIZE 6
                 ANTIALIAS TRUE
                 POSITION AUTO
                 FORCE TRUE
                 PARTIALS FALSE
                MINDISTANCE 300
                BUFFER 4
            END # end of label
    END
  END
  #Circle symbol
      SYMBOL
        NAME 'CIRCLE'
        TYPE ellipse
        FILLED true
        POINTS
          1 1
        END
      END
END
Problem is Openlayers.loadUrl(url, '', this, setHTML) does not work.
 It is saying Jscript runtime does not support this Object or property.
My script for calling GetFeatureInfo is as below:
<%@ Page Language="C#" AutoEventWireup="true"  CodeFile="Default.aspx.cs"
Inherits="_Default" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head id="Head1" runat="server">
    <title></title>
    <script   type="text/javascript"
src="OL28/OL28/lib/OpenLayers.js"></script>
    <script type="text/javascript">
        var mapview, layer, layer1, map;
        function init2() {
    </script>
</head>
<body>
    <form id="form1" runat="server">
    <div id="map" runat="server" style="width:600px;height:600px">
    <script defer="defer" type="text/javascript">
        OpenLayers.ProxyHost =
"http://172.16.0.144:9000/cgi-bin/proxy.cgi?url=";
        //alert('here');
        var lon = 73.25;
        var lat = 20.35;
        var zoom = 6;
        map = new OpenLayers.Map('<%=map.ClientID%>');
        //            layer = new OpenLayers.Layer.WMS("OpenLayers WMS",
        //                "http://localhost:9000/cgi-bin/mapserv.exe?", {
map: '../htdocs/Shape/newwr1rec.map', layers: 'STATE', format: 'png' });
        //            layer1 = new OpenLayers.Layer.WMS("Rstations",
map: '../htdocs/Shape/newwr1rec.map', transparent: true, layers:
'RailwayStations', format: 'png' });
        //alert(map);
"http://172.16.0.144:9000/cgi-bin/mapserv.exe?map=d:/ms4w/apache/htdocs/Shape/newwr1rec.map",
{ 'layers': 'STATE', transparent: false, format: "image/png" });
        layer1 = new OpenLayers.Layer.WMS("OpenLayers WMS",
{ 'layers': 'RailwayStations', transparent: true, format: "image/png" });
        //alert(layer);
        map.addLayers([layer, layer1]);
        //layer = new OpenLayers.Layer.WFS("OpenLayers WFS",
"http://127.0.0.1:9000/cgi-bin/mapserv.exe?map=d:/ms4w/apache/htdocs/Shape/newwr1.map",
{ typename: 'STATE', maxfeatures: 6 }, { featureClass:
OpenLayers.Feature.WFS });
        ///map.addLayer(layer);
        map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
        map.addControl(new OpenLayers.Control.LayerSwitcher());
        //map.zoomToMaxExtent();
        map.events.register('click', map, function(e) {
            //alert('clicked');
            OpenLayers.Util.getElement('nodeList').innerHTML = "Loading...
please wait...";
            var url = layer1.getFullRequestString({
                REQUEST: "GetFeatureInfo",
                EXCEPTIONS: "application/vnd.ogc.se_xml",
                BBOX: layer1.map.getExtent().toBBOX(),
                X: e.xy.x,
                Y: e.xy.y,
                INFO_FORMAT: 'text/html',
                QUERY_LAYERS: layer1.params.LAYERS,
                FEATURE_COUNT: 1,
                WIDTH: map.size.w,
                HEIGHT: map.size.h
            //  var msg = document.getElementById('urlmsg');
            //  msg.value = url;
            alert(url, "getfeatureinfo",
"location=0,status=0,scrollbars=1,width=800,height=400");
            //window.open(url, '', this, setHTML, setHTML);
            OpenLayers.loadUrl(url, '', this, setHTML);
            OpenLayers.Event.stop(e);
        function setHTML(response) {
response.responseText;
    </script>
    </div>
    <div id="nodelist">
    </div>
    </form>
</body>
</html>
I think it has something to do with proxy.I am showing map on a aspx page
using IIS.Could you pls try it yourself and let me know if it works for you.
thanks.
View this message in context: http://n2.nabble.com/Proxy-problem-in-GetFeatureInfo-no-solution-tp4802810p4822912.html
